03-28-2019, 11:59 AM
1st gear is currently set to 42mph. Which we find works perfectly for the CVT. May need to make a setting for the manual trans cars to roll it back to 20mph.
Car: 2018 Honda Accord Sport 1.5T
03-28-2019, 12:05 PM
Gotcha. And that setting is saying max "additional" boost? Or add no more than 3 psi boost until 42mph, over what the Honda programming would have added?
2018 Honda Accord 1.5T CVT
PRL Stage 1 Intake
BMS JB4
Enkei TFR Wheels
Car: 2017 crv
03-28-2019, 01:31 PM
Never heard of that before. If it was JB4 related you'd have a fault code for a sensor disconnected or similar.
Not sure if we have OBDII support for the 2017 CRV yet but plug it in and see if it changes anything. Maybe email in photos of install and JB4 board front and back so we can check for any damage/issues.
I've been emailing ando back and forth about my crv. The Logs I sent him aren't pulling up anything from the canbus. But he verified that it is installed correctly.
Car: 2017 crv
03-28-2019, 01:36 PM
Having troubles posting pictures from my phone on here
03-28-2019, 01:42 PM
No problem if you are already working with us via email no reason to double up the work on the forum. If Ando can't figure it out he will forward the email chain to me anyway.
03-28-2019, 01:44 PM
Boost is lowered by that value in that speed range.
03-28-2019, 02:58 PM
I just pulled the trigger on a dragy after watching reviews. Great item for $150. Can't wait to compare 0-60 on 0,1 and 2.
It's really useful for dialing in your launch too!
03-29-2019, 05:45 AM
Yeah, that makes sense. After I thought about it (duh), it runs much higher than 3 psi if you gas it from a start lol. I also like the safety feature of the engine needing to warm up before it really boosts it up. Since I bought the car, I do not drive it aggressively at all until I've gotten about 5 mins down the road.
PRL Stage 1 Intake
BMS JB4
Enkei TFR Wheels
Car: 2018 Civic Si
03-29-2019, 09:33 AM
AAAAAH! That's why I thought it wasn't working, haha. I thought that number was setting the max boost it would hit for that gear/speed. D'oh!
Mishimoto intake, resonator delete, Vibrant 1040 muffler, JB4 tuner, Firehawk Indy 500 rubber, Lamin-X fog light covers, Xentec 35w 6000k HIDs, custom d20 shift knob, 20% tint, red "H" badges.
Car: 2018 Civic Si
03-29-2019, 01:47 PM
Speeds:
1st - 32
2nd - 56
3rd - 86
4th - 115
5th - 137 (governor limited)
6th - 137 (governor limited)
Gear ratios:
1st: 3.64
2nd: 2.08
3rd: 1.36
4th: 1.02
5th: 0.83
6th: 0.69
Final: 4.11
Car: 2018 Civic Si
03-29-2019, 01:49 PM
This is for the Si; not sure if the non-Si manuals are the same.
03-29-2019, 08:54 PM
Try it again and log it.
Car: Honda C-RV
03-30-2019, 09:24 AM
Just to note I've had a jb4 in my crv since December with no issues running map 3 now except I disconnected my battery when I did it and it took 15 min to clear all the codes and reset the vss. I also taped the connections just in case as we get alot of water here.
Any thing I can help test for the crv? Ours is a RHD Thai built 2018, same as Aussie, SA and New Zeeland models with the 192 hp motor
03-30-2019, 10:08 AM
No issues on 2018+ CRV, CANBus and everything is working normally. Just need to confirm CANbus on 2017 models as they could be different.
Car: 2018 Civic Si
03-30-2019, 11:26 AM
Mobile app stopped connecting today. Worked fine yesterday. Phone sees it via Bluetooth, app opens, hit connect and it sees it and validates the PIN, but then it cycles through a few handshake attempts and errors out. Restarted the car and my phone, no luck. Tried holding the phone directly up to the BT module on the JB4, no luck.
Currently setting up on our extra phones just to troubleshoot if it's a phone issue or a JB4 issue. Once the software's updated and I install the app, I'll report back.
Car: 2018 Civic Si
03-30-2019, 11:38 AM
Okay, same issue with the spare phone. Sees it, pairs, validates PIN, but then fails at handshaking.
About to disconnect the tuner and pull it open to confirm all connections are secure.
Car: 2018 Civic Si
03-30-2019, 12:09 PM
Well, no idea what the problem was, but...
Disconnected the JB4, cracked it open and checked all connections (they were fine), put it back on, and my phone connected right away. Go figure, haha.
Car: Honda C-RV
03-30-2019, 01:32 PM
your Jb4 just wanted some attention.
Car: 2018 Civic Si
03-30-2019, 01:56 PM
Car: q50 redsport 400
2019 Acura RDX application? -
03-31-2019, 11:32 AM
Hi, just wondering if a jb4 application is in the works for the 2019 RDX? Should be possible as it shares the same motor as the new accord and type R? More power/torque would be great in the RDX. Thanks!
03-31-2019, 11:33 AM
Yes as far as I know, email us photos of the TMAP and MAP sensors and we can confirm and work with you.
04-02-2019, 05:09 AM
OK, so Map 2 has been working great. Reading Map 3 it is a little more boost, and 93 octane is the minimum? Are you seeing more knock control on Map 3, because I hardly see any on Map 2, but I run either Shell or Costco Top Tier 93 octane all the time.
Just starting to consider Map 3 as a daily driver setting, but not sure I need it. I still have Max Boost 1st set to 3psi for the CVT, and have Boost Safety set to 23psi.
Also just got the Dragy in, will have to find some time to make some Map 0 and Map 2 runs.
PRL Stage 1 Intake
BMS JB4
Enkei TFR Wheels
04-02-2019, 08:22 AM
Best way to evaluate maps if based on actual performance with dragy, to see if the extra boost is giving enough gain to be worth the small extra risk.
04-02-2019, 08:25 AM
Makes sense. End of the day the Accord is a heavier car and the turbo is small. I am def gonna do map 0 vs map 2 0-60 when I get a chance.
PRL Stage 1 Intake
BMS JB4
Enkei TFR Wheels
Car: 2018 Honda Civic Sport
04-02-2019, 08:48 AM
I decided to run 91 from Costco, and I'm on Map 3. I see between 0-25% knock control
When I was on Map 4 I pumped 94 from Chevron and didn't see much knock at all
