(#151)
Juan_BIGBOOST_TURBO's Avatar
Juan_BIGBOOST_TURBO Juan_BIGBOOST_TURBO is offline
Default 03-11-2017, 06:52 AM
Second N55 to get built at our shop
Name:  2017-03-11 08.54.12.jpg
BigBoost Instagram: @bigboostturbo
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
Current B58 record holder: Currently: 822 WHP
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
Default Product pictures - 03-21-2017, 02:48 PM
Hi All, yesterday we got some more pictures of the kit its self!
So here we have the E-Chassis turbo kit
Name:  Kit E_chassis 1 updated.jpg
And here we have the F-Chassis turbo kit, both EWG and PWG
Name:  Kit F_chassis 1 updated.jpg
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default Second batch ready! - 04-18-2017, 04:19 PM
Hi all!
We wanted to announce that we will have our second batch of turbo kits ready this week! We still have 3 turbo kits available to ship without fabrication awaiting time, either E or F-Chassis vehicles equipped with N55 engines These kits come with the new revised exhaust manifold. (Revision 3.5). Discounts Apply
Name:  N55 bbt exhaust gasket.jpg
Name:  Stage 3.3 turbo.jpg
Name:  Oil line with IC Billet coupler.jpg
Name:  N55 MANIFOLD 3.5.jpg
Name:  N55 manifold 3.5 1.jpg
Name:  N55 manifold 3.5 2.jpg
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 04-18-2017, 05:42 PM
Any of the N55 running Meth instead of PI ?
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
Default 04-18-2017, 06:16 PM
Yes, made 470 to the wheels with 501 FT-LB of torque with stage 3.1 maxing out the turbo.
It did have a flash tune, but the trims were a little high, so decided to leave it on 440 whp.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 04-18-2017, 06:36 PM
Any update on the build engine with stage 3.4 or 3.5?
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
Default 04-18-2017, 06:38 PM
We are fixing some HPFP issues we are having but we will soon have some results.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
ozuna ozuna is offline
Car: 650i
Default 04-19-2017, 02:52 AM
Let's say i want to run stage 3.3 without PI is it possible just like the Pure stage 2? i Know with the Pure turbo you can get roughly 450whp on the stock fuel system so i was wondering if i would be able to run your 3.3 kit on stock fuel system until funds allow for PI. Thanks!
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 04-19-2017, 02:55 AM
You most likely could, just run really low boost levels and taper boost down towards redline.
Mods: Stock for now
Default 04-19-2017, 04:03 AM
Exactly, as Lowon said, you can run max 17 psi without PI, lowering boost down to 15 PSI from 5800 to 7000 RPMs
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Car: 650i
Default 04-19-2017, 02:59 PM
How much power would the car make on those boost settings? Its a FBO EWG running JB4.
Lowon's Avatar
Car: Bmw M2
Default 04-19-2017, 03:11 PM
That's a pretty hard question to answer because power doesnt necessarily mean just sheerly high boost levels. It's a factor of fuel trims and afr, ignition timing, boost, altitude, octane used/fuel quality etc. I'm guessing 430whp+ maybe a bit more I'm not sure, w/o a flash. You may get a bit more with a flash dialing everything in.
Mods: Stock for now
Car: 650i
Default 04-19-2017, 03:16 PM
Thats a little disappointing lol
Lowon's Avatar
Car: Bmw M2
Default 04-19-2017, 05:09 PM
Well that's what happens if you cheap out on components. Always get supporting mods first before seeking big power, I know it's hard to resist but trust me the BMW community has it so easy with the ECU being so smart, and motors being this durable.
Mods: Stock for now
Default 04-19-2017, 05:30 PM
+1
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Frikiton's Avatar
Default 04-20-2017, 09:05 PM
Yep!
Arrow29 Arrow29 is offline
Car: 2013 BMW M135i
Default 04-22-2017, 02:19 AM
We have had many calls regarding RHD fit, so we are going to find out if it will fit, we will try to get an answer as soon as we can.
Any updates on this front, Juan? Not easy to get access to a RHD vehicle I imagine!
Cheers
2013 F20 M135i EWG. JB4, BCS DP, E30
Default 04-22-2017, 06:10 AM
Cheers
We already got some info on how the steering system goes on this vehicles, we are making some modifications to the manifold to fit the turbo a bit different for this cars.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Car: 2013 BMW M135i
Default 04-22-2017, 08:12 AM
Exciting news, thank you for the update and for making the effort! Will be watching this space closely
keyap keyap is offline
Car: N55 135i
Default 04-22-2017, 09:24 AM
Throttle's Avatar
Throttle Throttle is offline
Car: 08' 335xi
Default 05-06-2017, 01:03 PM
Does this turbo kit fit the F87 M2?
The reason I'm asking is because I was told by another big turbo kit company that the M2 motor mount is different than the F22. So the turbo may hit the motor mount in the F87 chassis. Please confirm.
2017 BMW M2 in Mineral Gray
DCT Transmission & Executive Package
Speedtech Stg 3 (8374) l BM3 Jordan Tuned l AA Intake l ER Chargepipe l ER FMIC l Stage 2 LPFP l EOS Pump Controller l XDI-35 HPFP l NGK 97506 l Ohlins R&T l SPL Suspension Parts l RE-71 Rís l BMW M Performance Kidney Grills, Mirror Covers, Spoiler, Rear Valence l Full PPF Wrap l 35% Tint l
Default 05-06-2017, 05:16 PM
Our kit does fit the M2 because we do not have to replace OEM RH engine mount. The turbo has a good clearance between turbo and engine mount.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Throttle's Avatar
Car: 08' 335xi
Default 05-06-2017, 06:42 PM
Thanks, that's good news. How quick is the spool with the stage 3.3 kit? Also, is there enough traction to use the 600 WHP?
Throttle's Avatar
Car: 08' 335xi
Default 05-06-2017, 06:51 PM
Default 05-06-2017, 07:34 PM
In our M235i it hooks up really well. In an M2 it should be even better. We achieve 23 PSI by 3700 RPMs, 18psi should be around 3200 RPMs
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
