(#2276)
Default 06-13-2019, 09:45 AM
That is all you need to do. Might be a touch of reverse adaption going on.
Team Tonka Team Tonka is offline
Car: G70
Default Fuel wire question.... - 06-13-2019, 04:50 PM
When checking on the short fuel wire with resistor, my multimeter that makes a "noise" if there is a connection and it isn't making a noise? Long wire does.
But, my other multimeter with OHM meter is reading .996 k-ohms, that correct for the short wire with resistor?
Default 06-13-2019, 08:12 PM
It's a 1k resistor so that sounds right to me.
Car: G70
Default 06-14-2019, 06:06 AM
Thanks Terry.
Here is a run from around 40-90mph with fuel wires now hooked up. Let me know if everything appears to be working the way it should please.
2019 G70 3.3T AWD with 93oct fuel, K&N panel filters, Pedal Tuner, everything else stock...
File Type: csv 2019-06-06 16_47_11_Map-1 40-90mph w-fuel wires.csv (7.7 KB, 3 views)
johnnhp johnnhp is offline
Car: 2019 Hyundai Sonata 2.0t
Default 06-14-2019, 11:21 AM
What does the map setting look like for Map 2? I want to use it as a baseline and then adjust off of it.
Default 06-14-2019, 11:32 AM
Originally Posted by Team Tonka
Thanks Terry.
Seems OK so far but lets see a longer run, with boost limiting this is more like a stock log.
Car: G70
Default 06-14-2019, 11:36 AM
What do you recommend I do to get a good log? 0-60? 0-90? Other?
Default Map run attached - 06-14-2019, 11:40 AM
Why do I not see gear or mph in data log?
Default 06-14-2019, 01:18 PM
Gear isn't active yet. Update your firmware for 2L road speed logging.
Default 06-15-2019, 09:08 AM
Something unique we've been testing for the few months, about ready to move in to production.
It's our Stinger air/oil separator. It's effectively similar to an oil catch can in that it captures oil that would otherwise make it through the PCV in to the intake manifold (gunking up your valves and lowering effective octane), but rather than having to continually monitor and empty the can every few months, this allows the oil to drain back in to your engine where it belongs! Took a few design tweaks to get it just right but we've been pretty happy with the performance of our latest revision. It's really stealthy too with the engine cover on.
Mickey14 Mickey14 is online now
Car: 2019 stinger gt1 awd
Default Yesterday, 07:07 AM
Hi terry
How long before its ready for purchasing
Default Yesterday, 08:26 AM
Should be a couple weeks for the first batch.
Default Yesterday, 08:30 AM
Cool I was going to do catch can but I can wait��keep me informed.any idea on pricing?
P4RTYH4RTY P4RTYH4RTY is offline
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default Yesterday, 02:06 PM
But where is the BMS Intercooler?
Default New Install, Map 2 Run - Today, 08:58 AM
Tell me if this run looks ok. I had pedal all the way down too, not sure why it only went up to 96.
Default Today, 09:31 AM
There are 150 cores sitting in our warehouse waiting for the end tanks to be welded on.
It obsoletes catch cans... $199 retail, little less on an intro price for the first 20 units. Won't be too long batch is in production.
Default Today, 09:33 AM
Looks good to me but next time grab the latest firmware so we see timing in cylinders 2-4 too.
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Mickey14
