(#401)
Default 06-12-2019, 10:25 PM
Yes that sounds right, it's a byproduct of the logic that the JB4 will always "attempt" to add 4psi regardless of pedal input. But you can only make more boost under heavier pedal input anyway.
Austype R Austype R is offline
Car: Honda Civic type R
Default 06-13-2019, 05:27 AM
hey Terry
is map 6 usable on type R? I can select it just not sure if active. I think I got wrong obdII cable as too short but so far so good. I tried both map 1 and 2 with no problems. I have been on civicx forum there is a bit of h8 for jb4 there, I'm trying to make them believers.
Default 06-13-2019, 08:19 AM
Yes map6 is active and can be used to manually set profiles. The limiting factor with the R is fuel pressure though.
On OBDII tuner goes on the driver side so the cable should reach. Photos? We have a longer cable too we can send if needed.
Default 06-13-2019, 09:13 AM
I'm in Australia so steering wheel is on other side
Default 06-13-2019, 09:45 AM
Ahh makes sense. Normally AU gets the longer cable anyway. Was your cable 4' or 6'?
Default 06-13-2019, 10:01 AM
ok I was going to place jb4 next to airbox but no way does obdII reach over there so now I run jb4 on other side but it's a bit close to the belt and hot *****.
MarcoTypeR MarcoTypeR is offline
Car: Honda Civic Type R
Default 06-13-2019, 08:01 PM
Hello Terry, here is a long log from the track to review. Map 1, Type R, 94 octane
JrodR24039 JrodR24039 is offline
Car: Honda civic Type R
Default e40 - 06-14-2019, 06:27 PM
Originally Posted by JrodR24039
Hey guys, I have a question. I'm running map 2 on my type R. i noticed that it seems to have a lag. lets say I'm on second gear pushing around 2500 RPM and punch the throttle down. It feels like its lagging or idk what it is. but once it passes 4k its normal. is this boost lag or maybe my 93 gas? or is this considered boost lag?
So i started experimenting with different fuel mixtures, e20, e30, e40.
E40 proved to be the most effective, no more lag seems like it was not the fuel pump but the octane, Heck I ran it on map 3 NO ISSUES ran like a champ.
Mishi intake, **, JB4
Default 06-14-2019, 09:12 PM
Surprised the fuel pressure is holding up on R!
Default 06-14-2019, 09:21 PM
I think the max boost I've seen has been 22-23psi with E40. In our car group (TYPERSOFSOFLO) we have multiple type Rs runing 24-28psi with stock fuel system but they are FBO, running hondata, Ktuner, ect.
In all E40 is the way to go. Map 3 is great
Default 06-14-2019, 09:32 PM
Yes with the flash tuning they can probably set the AFR a lot leaner to try to get away with it. We're limited by the factory like air/fuel targets with the JB4. Which are richer and more conservative. But also hits the fuel pressure limits earlier than running leaner.
Default 06-15-2019, 10:15 PM
It would be good for guys to start logging e20,e40 to see what’s happening. Is map 3 active on type r? I thought it was just 1 and 2
Default Yesterday, 01:55 PM
Lots are always a good idea.. The TypeR we used for development was not very E85 friendly based on fuel pressure. Your mileage may vary.
