Default JB4 for Porsche 718 - 02-17-2019, 02:52 PM
Order here: http://www.burgertuning.com/PORSCHE_718_JB4_tuner.html
We'll use this thread for our upcoming Audi RS3 & TTRS JB4 SENT BETA updates, map guides, firmware, and discussion!
Install Guide here: http://www.burgertuning.com/instruct...tall_guide.pdf
Optional map changing, datalogging and updates are done using the BMS data cable or JB4 Mobile REV3 bluetooth kit.
BMS data cable hard wired directions and software Click here
Map guide as of v1 firmware:
Map0: Stock tuning, disable JB4
Map1: (default map) 2psi peak over stock
Map2: 3psi peak over stock
Map3: 4psi peak over stock
Map4: 5psi peak over stock
map5: Under development
Map7: Under development
Map8: Under development
Firmware:
718_1: Initial firmware.
How to update firmware via JB4 Mobile:
Obx_jk Obx_jk is offline
Car: Porsche 718
Default 03-30-2019, 04:07 PM
I’ve installed mine. Need some help understanding which map is which. Also the Bluetooth is not connecting to the the gauges. It will for a moment, but then goes to zero. Two gauges will work but doesn’t seem real time.
Default 03-30-2019, 04:40 PM
Latest firmware is in the first post. Will reply to your email re: troubleshooting and add in map guide here shortly. Default is map1 so you can stay on that for now.
Brown109 Brown109 is offline
Default 04-25-2019, 12:17 PM
Do any of the maps currently available require any modifications?
Default 04-25-2019, 02:57 PM
No they don't.
leogets954 leogets954 is offline
Kill Mode RC
Car: porsche 718 GTS
Default 05-21-2019, 10:39 AM
Ordering mine now for my 718 GTS. Will be running a ******* ********. Do I need to use a specific map, or will I need an O2 Spacer?
Default 05-21-2019, 11:14 AM
Inside USA we can't provide any advice. Outside USA there is a passive delete option for those.
Kill Mode RC
Default 05-21-2019, 11:34 AM
Sorry Terry, I should have mentioned the car will be used for track racing only. Where would I find information on the passive delete option?
Fred V Fred V is offline
Car: 718 Cayman
Default 05-23-2019, 01:33 PM
I just purchased it and will have it installed very shortly. Very excited. The dyno charts posted on the order page are for a base model running E26 fuel correct?
What are the power gains for each maps on regular 91/94 fuel?
Kill Mode RC
Default 05-23-2019, 01:58 PM
I dyno'd my stock GTS on sunday. 91 degrees, 65% humidity, 700miles on the odometer. made 354hp/ 335torque.
Kill Mode RC
Default 05-23-2019, 01:59 PM
I dyno'd my stock GTS on sunday. 91 degrees, 65% humidity, 700miles on the odometer. made 354hp/ 335torque. will dyno the jb4 when I get it.
Car: 718 Cayman
Default 05-24-2019, 10:41 AM
I'm very curious about the base model since this is what I have, and everything seems to be about the 2.5
Default 05-24-2019, 05:11 PM
Sounds good! Steve can help you crank up the boost too if you need.
Kill Mode RC
Default 06-05-2019, 08:58 AM
Has there been any updates on the progress of Maps 5-8?
Default 06-05-2019, 02:53 PM
No we haven't done any higher maps yet, as Steve is continuing fuel development so we can determine how far we can safely push it.
Kill Mode RC
Default 06-06-2019, 09:59 AM
Sounds good! Just ordered mine for my gts yesterday! cant wait!
Default 06-06-2019, 11:01 AM
Harnesses are on back order for a couple weeks I think, but we'll ship it as soon as we can.
