Car: N54 335i
E85 help!! -
12-28-2019, 11:45 PM
Hello everybody, so today I pulled all my injectors and cleaned all them, after I decided to run E85 for the first time. I accidentally went up to 3 gals and stopped. I had about a gallon of gas in the tank then filled the E85 then the gas I did about 13.5 gallons of 91. I have a JB4 running on Map 5, I finish up and drive down the street then I got a message saying my motor is running to hot. I check my JB4 and it says my water temp is running at 240... I put on the E85 display on my JB4 and it says E85 = 55? Does that mean it’s E55? And I’m running to much E85? My car seems very laggy and doesn’t really feel good at all! Does anybody have an idea?? Im going to let the car sit over night and hopefully it mixes. Maybe I did something wrong? Someone please help! Thanks guys.
problem...
so I found out today that my water pump happened to take a dump on me as soon as i put E85 in... what are the chances �� fan is on 24/7 on max and I tried to bleed my system and nothing. It just makes a horrible noise. Lucky me!!!!
Car: E60 535i
12-29-2019, 07:39 AM
Wow, you've mashed a lot into one thread. Here is my personal, non-mechanic, N54 DIY guy opinion:
- You've done major work to your car recently, don't discount any of that OR pure coincidence with current symptoms of overheating and general lumpiness
- JB4 does not read ethanol unless you have an ethanol sensor in place and hooked up to your JB4 (you would know if you did this). Readings are NOT actual ethanol % without a sensor
- 3 gallons of e85 is not too much ethanol for a full tank, it should run better with ethanol. Above 30% or so ethanol you will need a back end flash (BEF), Pump for 30% or e85 for 40% - 50% ethanol for best performance
-Keep working at it, if you can remove your injectors for cleaning, you are DIY enough to figure this out and fix it
Car: N54 335i
12-29-2019, 02:10 PM
Oh wow, I thought on map 5 it auto tunes and adjust to the E85🙄. I’ve done a lot of work to my car but I was just wondering if anybody had ever heard of what’s going on? Doesn’t make sense to me lol. But thank you for the help
Car: E60 535i
12-29-2019, 08:49 PM
Map 5 auto tune adjusts to the beneficial effects of added ethanol but the actual ethanol content is not read by the tune. It's a subtle but important thing to know. The actual ethanol content is useful to know when to add an appropriate Back End Flash or to understand where your fuel system will max out. BMS has a simple test tube type ethanol testing kit.
I check my ethanol content after every fill up and calculate for 45%. I find close to 50% and my trims and fuel pressures start to falter. Dipping less than 40% and my timing is not as good and performance drops. To me it's part of the hobby of tuning the N54. Keep reading and testing and posting. Good luck.
12-29-2019, 08:53 PM
Attach CSV log, not a photo of the CSV.
12-29-2019, 09:10 PM
Sucks about the water pump, but it does seem to happen randomly.
As far as your e85 question, every car is different, but assuming your high / low pressure fuel pumps aren’t in horrible shape, 3 gallons of e85 wouldn’t be “too much.”
Once you get the water pump fixed, throw up a log & we can see what’s going on with the car feeling laggy.
Car: N54 335i
12-29-2019, 09:41 PM
Hello Terry, I attached a log for you and Dave to view if you would like! Thank you!
Car: N54 335i
12-30-2019, 02:34 PM
Hey Dave, I posted a log on my original post, I believe my car was lagging due to my car overheating bc of the pump being a fail safe probably. I guess we’ll see when I get my new pump what happens! Thanks for the help!
12-30-2019, 04:06 PM
Few things you’ll want to do- enable 6cyl timing so we can see what’s going on, on multiple cylinders.
Also, your LPFP, looks to be touching the 50s, with that little e85 in the tank- you might want to upgrade that next, if you wish to continue using e85
Car: N54 335i
12-30-2019, 04:14 PM
Ok! I’ll enable that right now! I’m still pretty new to all then JB4 stuff only had it for about 2 weeks. Also I kinda figured it would be time for a new LPFP it’s stock pump from 2008! Thanks for the help!!!
01-01-2020, 01:12 PM
No worries
Check out our stickied posts should help get you up to speed
Car: BMW 335I
01-08-2020, 10:29 PM
OP I had the same issue with my stock lpfp, put in a fuel it stage 2 lpfp with upgraded E85 fuel lines and bluetooth ethanol sensor and was running up to E 57 before slight timing and fueling issues running stock turbos at the time. Also had JB4+MHD BEF FBO
Thread Tools |
Display Modes |
