Ifreezebmx562 Ifreezebmx562 is offline
Car: N54 335i
Default 11-24-2019, 05:26 AM
Hello, thanks for all the replies everyone, I made a little video to show you guys the best sounding N54 out there lol. It’s bad and unfortunately it makes me not want to drive my car.
Enjoy N54 exhaust sounds horrible. - YouTube
Car: 2008 E93
Default 11-24-2019, 10:04 AM
Sorry homie
It sounds uhhhhhh, different.
Do you have a current log by chance ?
Car: N54 335i
Default 11-24-2019, 05:13 PM
Sorry homie
I don’t... I wish I did. My car also seems to be running rich on the fuel side...
Haynpunch's Avatar
Car: 07 E90 335i
Default 11-24-2019, 05:23 PM
Are you running a tune? MHD, JB4, Custom?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 2008 E93
Default 11-24-2019, 05:27 PM
Did the running rich part happen when you did deepees ? Or was it a prior issue ?
Sidenote, be careful with Seal Beach cops. They go after STOCK exhaust if they are a lil loud .
Car: N54 335i
Default 11-24-2019, 05:37 PM
I am currently not running any tune.
Car: N54 335i
this was after the ******** that i started to run rich.
also i was just there Friday lol one was giving me the eye.
Car: 2008 E93
Default 11-24-2019, 06:25 PM
Sounds like 02 issues. Something must have gone wrong during install. Any codes popping up ?
Yeah, I go the long way around and avoid S.B. MOST of the time. Every now and then I risk it, but they already got me once so.....
Car: N54 335i
Default 11-24-2019, 07:01 PM
Here are my currently codes according to Carly.
Car: N54 335i
Default 11-24-2019, 07:20 PM
I posted a reply about my current codes
Car: 2008 E93
Default 11-26-2019, 04:04 PM
Hard to say. Seems like CLDP Codes. Without the car in front of me its just a guessing game. Does it boost the same ? Any loss in power ? Possible waste gate rattle more pronounced with deepees ?
Car: N54 335i
Default 11-27-2019, 01:59 AM
Boost feels a little bit sluggish, and the wg rattle seemed a little bit louder after deepees’s
Car: 2008 E93
Default 11-27-2019, 09:58 AM
I would check v band clamps. Its possible they are in the way of the actuator arms. Wastegates are normally open. So it may look fine, until you try and boost.
codesx's Avatar
codesx codesx is offline
Default 11-27-2019, 10:36 AM
I'm reaching, but any chance the cats were cut out and a piece of metal got into the exhaust, causing a partial blockage?
Like THE BEAST says, focus on the actuators.
Maybe get a log at 1500 RPM, WOT, high gear so you have time to hit target boost.
Then another at 4500 RPM, WOT, high gear so boost and target can be evaluated.
Then a log in 3rd from 1500 to 6500 RPM to see how the target and value track - this may help expose if there is an actuator interruption or exhaust restriction.
Just a layman's thoughts.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 E93
Default 11-27-2019, 10:46 AM
He doesnt have a JB4
Car: 2003 Forester
Default 11-27-2019, 11:42 AM
It sounds like an exhaust leak to me. ¯\_(ツ)_/¯
codesx's Avatar
Default 11-27-2019, 01:03 PM
Wow. Didn't think it was an option these days.
I guess I did read that above... just didn't register.
Get it. It'll change your world ... and make troubleshooting easier.
End of message. Sigh.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: N54 335i
Default 11-28-2019, 04:00 PM
I will deff take a look at that, hopfully its something small!
Car: N54 335i
Default 11-28-2019, 04:01 PM
Once i get my JB4 in week ill be able to take a look and post my logs! hopefully ill be able to whats going on off my logs!
Car: N54 335i
Default 11-28-2019, 04:02 PM
Next week it will be in!
inline6xi inline6xi is offline
Car: 2008 bmw 535xi
Default 11-29-2019, 10:19 PM
agree. It sounds like something mechanical dude.
honestly the maracca/ rattle sounds like the time I had weld on a baffle pop loose inside one of my exhaust cans. I really think its something mechanical in your piping, and possibly in combination with an exhaust leak.
probably not what you wanted to hear but I would go through the exhaust, maybe tap on the mufflers/resonators/cats when they are cold, and when they are warm (be careful of course).
when my baffles popped loose i could only hear them once the exhaust was at full operating temperature, which made it extra baffling (sorry, had to) when I would tap on the cans when the vehicle was cold.
ReforMatt ReforMatt is offline
Car: 2010 E92 335i
Default 12-02-2019, 03:16 PM
Took me a bit to figure out what the heck I was seeing next too the frame rail...Ball-cap sadly.... I may or may not have spent a little too much time on my back looking up at my frame rails...
Car: 2008 E93
Default 12-02-2019, 11:21 PM
Say no to drugs.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 12-03-2019, 01:40 PM
Listened to the video, sounds like an exhaust leak. I would guess you either forgot the O ring at the ******** turbo connection or possibly where it bolts to the exhaust.
My guess is at the turbo though as it would explain your codes
09 335 - 6266
07 335i - 6870, E85 - SOLD
