(#51)
Default 02-04-2020, 08:02 AM
N54 life.
Will get you sorted before spring
Wrecker 426's Avatar
Wrecker 426 Wrecker 426 is offline
Car: 335xi
Default 02-14-2020, 01:08 PM
Move the ground off the battery to the frame, and the power off the battery to the frame terminal on the fender well. Also was only reading 11.2v at my Hobbs switch and 12.4 everywhere else so I moved the power to the jump post.
Attached is a new log
Still needs a starter, and some fresh E85, can tell there is water in it.
07' 335xi, VTT Stage 2, Meth CM10, Stage 2 LPFP pri, walbro 525 LPFP 2nd, JB4 E85 BEF, VRSF exhaust, Phoenix Race IC, MMP AL inlets, VTT AL Outlet, PR Coils, Fuel-IT CPI 950cc, Manual swapped, SMF Spec Twin disk
Car: 335xi
Default 03-21-2020, 12:28 PM
Here are some new logs, had a brand new dead battery after my month long work trip,
Car: 335xi
Default 03-21-2020, 12:30 PM
Had to fix a blown boot and worked in a battery **** off prior to those logs, and replaced my starter, starts super quick now.
Car: 335xi
Default 03-25-2020, 05:20 PM
Any help with the Logs I posted 2 up is appreciated
Default 03-25-2020, 10:14 PM
Your map 6 logs
Your last log looks best boost wise / curve wise & overall
How does the car feel ?
Car: 335xi
Default 03-26-2020, 08:11 AM
It feels like it has more in it, and pulls consistent, untill the trims kick it wich is very noticeable, the only change was the maps
Default 03-26-2020, 11:26 AM
From 5.5k to redline, let’s bunp your duty bias up a bit, keep the values close, but bump those up a tad.
Take 2-3 WOT pulls to adapt & log the next 2
Car: 335xi
Default 04-02-2020, 04:53 PM
Some new data logs, if start in 2nd it trips up trim safety, however my rolling 3rd pulls are more clean, think probably need to add some more?
Default 04-03-2020, 06:09 AM
Yeah add a tad more & let’s see
Car: 335xi
Default 04-09-2020, 06:51 PM
Got some pulls, felt pretty good, finally got my 17x9’s so I can get my 275’s on. I’ll get new data after.
One weird thing I had happen was the whole dash shut off then/now my meth pump will not shut off whole the engine is running. Did the FSB take a ****?
Car: 335xi
Default 04-10-2020, 09:09 AM
Here are some longer pulls, trims on 2 tanked on the one, no idea, on the other it’s still dropping a bit, went from 3-6 on it so it’s sustained, duty is already at 75 at peak rpm.
Also any insight on the FSB and meth pump stuck on?
Default 04-11-2020, 08:45 AM
Something looks off with boost as well- wgdc looks maxed & your pretty under target
Car: 335xi
Default 04-11-2020, 11:10 AM
yeah i was wondering why the boost wasn't getting as high anymore, iv had it go upwards of 34 (on accident) but a sustained 28 prior. Is it a boost leak?
Default 04-11-2020, 07:47 PM
Looks like a boost or vac leak somewhere
Car: 335xi
Default 04-13-2020, 05:43 PM
Found a vacuum line melted a bit from the canister, so I replaced that, and an ignition could partial disconnected.
Got some logs, almost made it worse
Default 04-14-2020, 07:19 AM
On that second log it looked like you were getting some trim variance bank to bank.
The last log, the 4th gear pull looks pretty decent. Wgdc looks a lot more normal.
But you think the cars running worse?
Car: 335xi
Default 04-14-2020, 08:40 AM
Well it could have been the surroundings, as I was dealing with traffic and not fully in tune with the car, it did go into safe maps a few times, well all but 2 times. Could have been it just adjusting back I guess. But still wasn’t hitting or getting to 28psi like I was asking it too.
