Move the ground off the battery to the frame, and the power off the battery to the frame terminal on the fender well. Also was only reading 11.2v at my Hobbs switch and 12.4 everywhere else so I moved the power to the jump post.
Attached is a new log
Still needs a starter, and some fresh E85, can tell there is water in it.
Your last log looks best boost wise / curve wise & overall
How does the car feel ?
From 5.5k to redline, let’s bunp your duty bias up a bit, keep the values close, but bump those up a tad.
Take 2-3 WOT pulls to adapt & log the next 2
Here are some longer pulls, trims on 2 tanked on the one, no idea, on the other it’s still dropping a bit, went from 3-6 on it so it’s sustained, duty is already at 75 at peak rpm.
Also any insight on the FSB and meth pump stuck on?
Something looks off with boost as well- wgdc looks maxed & your pretty under target
yeah i was wondering why the boost wasn't getting as high anymore, iv had it go upwards of 34 (on accident) but a sustained 28 prior. Is it a boost leak?
Looks like a boost or vac leak somewhere
On that second log it looked like you were getting some trim variance bank to bank.
The last log, the 4th gear pull looks pretty decent. Wgdc looks a lot more normal.
But you think the cars running worse?
Well it could have been the surroundings, as I was dealing with traffic and not fully in tune with the car, it did go into safe maps a few times, well all but 2 times. Could have been it just adjusting back I guess. But still wasn’t hitting or getting to 28psi like I was asking it too.
