can you still launch with 2 step + anti lag? my car stumbles and stalls when i try? anyone else have this issue
09 n54 AT e85 bef
No it doesn't really work well for automatics, just makes noise. Best launches are off anti-lag alone brake boosting. I'd decouple the 2step from the anti-lag by unselected the WMI bit.
Unselecting wmi bit3 doesn’t make it.. The relay and wiring has to be removed.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Jb4 antilag + 2step not working -
09-07-2019, 12:16 PM
2008 bmw 335xi 6speed
Hey everyone, I am trying to get the crazy pops that Terry shows in his antilag 2step video. I'm all up to date on jb4 and bef and also have the 2step relay. For some reason it is not letting me save bit3 when I try to turn it on. I have not been able to successfully get antilag to work even on its own. Any help is appreciated!
What happens when you select it and press save twice?
It won't even let me click save. I can try double clicking it tomorrow again. When I tried the other day I clicked save a ton of times and it wouldn't do anything.
Just finished the install of the Anti lag / 2Step running firmware 32_14_T11 (just switched from 32_12_T10)not sure if this is the one i should be using as its a bit confusing to me on which one i should use lol im also running a BEF Ije0s or w.e it is Pump Tune. Just about to head out the door and try it out. Hopefully all goes well id post some logs following it but not sure if its worth it. Ive got a Boost leak in my silicone intercooler to turbo charge pipe from the exhaust manifold burning it. Ive got the new one coming in on Tuesday hopefully.
Im Happy asf tbh. At first it wouldnt let me 2step in N and then outta no where a SHOTGUN BOOMB! lol and then it started to work. Once it bounced at set RPM for maybe 2 revs then shot up as if there was no 2 step and i was flooring it. Anti lag works aswell but ive ran into a problem with off the line launch it builds up then starts to bog out like its going to die. happend twice so far but worked for the most part. But id like to maybe build a bit more boost on the first gear launch is the acheived by raising the 1 gear boost limits ? Antilag and 2 stepp is hella funn for the rolling races sound like im MT and sick ASF. I use the Vol Down button for the rolling ones so much funner and eaiser. i figured how to properly do it after failed attempts. Now one thing im not able to figure out is how to antilag and 2step off the line. My method of trying is. Hold Brakes, Floor it, then Channel Down. But nothing but failed attemps.
all in all im happy with all of it the JB4, add ons and the support.
Cant forget The Man Terry. What would us n54 guys be doing without him.... I Thank you for everything and more.
Someone asked this but i didn't see a response. But when doing a burnout with a manual, 2 step kicks in when the brake is depressed not letting me do a burnout. Any ideas?
FUD:
bit0 - Disable steering wheel controls.
bit2 - Use water temp in place of oil temp for warm up safety.
bit3 - Disable open loop fuel learning.
bit4 - Enable BETA Anti-Bog-Logic (Manual Trans Only, v32_11+) bit5 - Block anti-lag from engaging on brake pedal, use volume only
bit6 - Disable FF RPM gain so duty bias RPM gain can be manually set more precisely.
bit7 - Alternative anti-rattle algorithm
What about normal anti-lag (not coupled with 2STEP relay)?
No you just unselect the WMI option to link the two.
I've been playing around with the anti lag on my new turbo setup, but my RPMs dont seem to hold while I have the antilag active. I press the volume down button then pedal the throttle and the rpms hold at around 4200 in 3rd gear for a second then the car takes off without me releasing the volume button. Is this normal?
NLS not working on Firmware 32_15 beta -
02-13-2020, 05:53 PM
Note: Firmware and use notes to enable this is now in the specificJB4 threads!
So it turns out JB4 2STEP + JB4 anti-lag = awesome!
Do do this you need:
1) A general understanding of how the JB4 and firmware updates work. If you don't know how to update firmware you probably don't have the requirements to run this.
2) JB4 anti-lag working including back end flash map loaded all per the first post in this thread.
3) The 2STEP relay installed and generally working.
4) The firmware below which integrates the two together while under two-step.
To enable antilag+2STEP integration with v14+ firmware set bit3 on the WMI page (mislabeled DTML WMI input) on.
I'd start at 3000-4000rpm as a set point on menu8 and evaluate from there. The anti-lag integration will probably require some additional adjustment to our 2STEP targeting logic so I'd be curious to see how it targets various set points for various turbos and flywheels.
Hi Terry,
I am brand new to this forum and somewhat forums in general so if I miss use educate or post in the wrong area please correct me and direct me in the right direction.
I have a 2008 335xi N54. I am a big fan of BMS and live near by the Simi location warehouse. I have recently installed both 2-step and Anti-Lag and I would like to be very thorough on my installation and functionality. I’ve read as much as I could but still have some question on operation.
From my understanding if you are running 32_15 firmware on the JB4 you DO NOT need to install the green clutch wire included. I have installed everything and updated to 32_15 and have operation of my 2-step when holding the clutch down and setting my rpm in menu 8. I also have full functionality of my anti-Lag as well. 2-step and anti lag work together at a stop when I hold the clutch rev to my set limiter and press the down volume button. So it seems those functions are working.
For the NLS, when I hold my foot all the way down on the accelerator during shifts the rpms shoot up instead of “dropping like a rock” and making pops or anything. I am unsure if it’s functioning but it doesn’t seem to be working. Again, I did not Install the clutch wire. Does this need to be installed to work? Possibly I’m confused. Let me know what information you need from me to determine this. Thanks!
