ccochrane ccochrane is offline
Car: 2011 F10 535MSport
Default Overboosting and triggering "Safety" - 09-13-2019, 07:05 AM
2011 F10 535 MSport with PWG. Full stock setup for now.
I recently resoldered the cut diode to move to the latest firmware for the PWG.
Everything looked and felt great for about a month.
I am now getting over 20psi on Map 1 and triggering the "Safety" mode.
It happens FREQUENTLY under partial throttle and sometimes on a full pull.
I changed a couple of the lower RPM duty Bias settings and increased the PID Gain to 20 and it seems to be better on full throttle 3rd gear pulls. It stays around 17-19psi. But I still get the overboost on partial throttle and once in a while on a full pull.
Is there something wrong with the system? The settings? Or am I just lucky and get the gift of greater boost?
Also - The "Target Boost" gauge no longer works (it also doesn't show correctly in logs)
Default 09-19-2019, 05:40 AM
Would LOVE some help with this.
Default 09-20-2019, 10:56 AM
Is it getting a bit colder temp wise wherever you live?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 09-20-2019, 11:59 AM
Yes. But it was not cool on the days I ran those logs. I would guess at least over 80deg F.
I also had the overboost on VERY hot days.
Default 09-22-2019, 03:06 PM
ANYBODY??
Or anybody from Burger care to help with this problem with your product?
Default 09-23-2019, 02:14 PM
Can we see a pic of your settings?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 09-25-2019, 01:22 PM
Attached are pictures of the settings page and 2 new logs.
1 log is a partial throttle pull with an overboost where it went into safety mode.
The other is a 3rd gear pull with overboost and it went into safety mode.
Temp was around 80deg F
Any ideas would be appreciated.
Default 09-25-2019, 03:51 PM
Something is wrong physically. Can't be a software setting issue as JB4 WGDC is low. Boost should be low too.
Probably a seized WG or maybe electrical issue with the solenoid connection or solenoid?
Default 09-28-2019, 06:55 AM
Thanks.
I am searching for how to diagnose that.
It seems like if the wastegate is "stuck" the Boost should be too high all the time. But it isn't.
It also is able to lower the boost every time it hits the limit and goes into "safe mode".
So it may be out of adjustment, but it doesn't seem like it is "stuck".
I can't find any other way to test that.
Any ideas?
If it is the boost solenoid, how would I diagnose that?
All the info I have found is how to diagnose an "under boost".
How would I check it for allowing an overboost other than just throwing a new part at it?
