Sam J Sam J is offline
Car: Bmw 135i E82
Thumbs down E series to F series N55 engine transplant help needed - 06-14-2017, 02:08 PM
Hello everybody,
My second car an M235i had a blown engine. We swapped the engine to an E type n55 engine.
Has anybody experience with this swap?
We kept the vacuum fuel pump from my original engine (f type) and now the chain guide has broken for a second time in 3000 miles. Could this be related?
Thanks very much, please look at the pictures.
#problemchildcar
Greets Sam
Stoolz Stoolz is offline
Car: 11 135i
Default 06-14-2017, 03:11 PM
JacquesN55 swapped an F series engjne into his E series I'm pretty certain.
He's currently working on a custom turbo setup.
Maybe PM him.
Car: Bmw 135i E82
Default 06-14-2017, 03:34 PM
Maybe PM him.
Thanx I will do that!
houtan houtan is offline
Default 12-30-2018, 10:52 PM
Did you ever figure out what caused the issue?
Car: 2011 N55 135DCT
Default 12-31-2018, 12:07 AM
Hi i swapped a F series into my E series. No issues
Default 12-31-2018, 09:43 AM
Thanks. I remember you did the swap. Just wondering if the op figured out what was causing his issue.
cranelec cranelec is offline
Car: '11 335i xDrive
Default 12-31-2018, 10:49 AM
JacquesN55, how did you handle the difference in fuel pumps? I'm about to return a 2015 N55 with the Bosch fuel pump because I'm not sure swapping the Continental fuel pump is possible in my 2011 335i xdrive due to the difference in vacuum pump chain tensioners?
