(#351)
blackgti blackgti is offline
Car: M235I
Default 06-16-2019, 11:21 AM
Originally Posted by dgraham1284
Checked the air filter to make sure it's clean?
I ended up reading it with Vagcom and it ended up being a P013E code not P0100 like the JB4 app said. Iíll have to fiddle with the spacer.
TSI 1.8T Jasper's Avatar
TSI 1.8T Jasper TSI 1.8T Jasper is offline
Car: 2018 mk7.5 1.8T m/t
Default 06-16-2019, 12:33 PM
For guys with the idle hiccup see if this firmware irons it out. Been sending it out to individuals for the past week and it seems to be eliminated with smoother spool up as well.
Let me know your findings.
Once we happy with the results we will add new maps to this and post it in post 1.
Took the car for good spin today , once car worms up the hiccups are still present at idle not bad but do come on and off. Otherwise car drives as should and does feel smoother with turbo spool up .
No codes ,no engine light all good but unfortunately still have the hiccups
julian2292 julian2292 is offline
Car: bmw 1m
Default 06-17-2019, 08:01 AM
Thanks for the new firmware George.
I am going to try it tonight.
audi s3 2019
aphex13 aphex13 is offline
Car: 2017 VW GTI SE
Default 06-17-2019, 11:08 AM
2017 VW GTI SE DSG...
The new firmware spools much smother than the last.
My exhaust tone seems more smooth/consistent as well. The DSG bangs are more like a brap than a pop.
I never really had any "trouble" at idle, but it seems to be smoother than before. This may be placebo. I'm going to revert to the last release this afternoon, just to check.
What was changed in the new test version?
Default 06-17-2019, 12:08 PM
We changed data sampling rates and some boost add onset speed. We going to add the two maps I want to add now and most likely go public with it this week.
Default 06-17-2019, 12:10 PM
Originally Posted by _Dejan_
I will try. Today Im try after long time push car harder and get issue in 5th gear.
Im start in 3th gear and then in 5th gear after gear change is car normaly pull but few seconds later it lose power and JB4 is change to map 4(Boost is over 28,1 for too long). Log is in attachment. Im also upload it on datazap:
https:// datazap . me /u/dejan/jb4-map6-fol45-maxpsi-28-boost-redux-65-30052019-boost-issue?log=0&data=1-4
Do you maybe know why ECU request that high boost?
At 5500rpm in 3th gear ECU request 15.1psi
At 5500rpm in 4th gear ECU request 19.4psi
At 5500rpm in 5th gear ECU request 21.7psi
Also ECU half close throttle after gear change to 5th gear.
I will in next days test it on map 0 to see if this strange behavior will still be present...
I got your email but for the guys reading the answer is the boost is load based. The higher the gear the more the load so it will boost more.
I think the overboost issue is elevated due to the GPF and changes they have made to the exhaust in this regard with too much back pressure at very high boost levels.
_Dejan_ _Dejan_ is offline
Car: Seat Cupra ST 300 4DRIVE DSG
Default 06-17-2019, 12:24 PM
George thanks for reply on email and here. My car is pre GPF so stoch has not have GPF but maybe Cupra 300 ST 4DRIVE have more restricted exhaust(Because stock has been very silenet) and they make changes in ECU to fight with backpressure...
andrew626 andrew626 is offline
Car: golf r
Default 06-17-2019, 02:08 PM
Wow great !
Default 06-17-2019, 03:12 PM
Will the two new maps work with 1.8T ? Would be nice before thursday cos going on a road trip friday ...haha no rush .
Default 06-17-2019, 05:01 PM
One yes the other no as its a high absolute map.
Default 06-17-2019, 08:21 PM
cool and thanks
sprinks sprinks is offline
Car: VW GTI mk7
Default Today, 06:37 AM
It feels great so far. It's so smooth that I honestly had a moment the day after install that i had to double check i wasn't in map0. Thank you for the updates!
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
