13F10M5 13F10M5 is offline
Car: F10 M5
Default BMS Stage 1 - S63TU M5 - 08-04-2015, 01:11 PM
Terry,
I connected my Stage 1 unit to my PC and when connected, I changed the boost safety to 4.0 but when I save the settings and it refreshes, it changes to 3.4. Does the same if I change it from 4 to another number. Seems to refresh to a lower number each time.
Is this a normal characteristic of the software/piggy back?
Default 08-05-2015, 11:39 AM
Perhaps you are using the wrong interface for your board. Screen shot of user adjustment page?
Car: F10 M5
Default 08-06-2015, 07:18 PM
Here are before & after screen shots. Before is when I connect to the board and after when I save the setting which changes from 4 to 3.4. When I refresh the connection (disconnect/reconnect), it displays 3.4. I tried this on two different stage 1 boards and got the same results.
garyf10m5 garyf10m5 is offline
Car: F10 M5 CP
Default 08-07-2015, 05:21 AM
Pretty sure you got the wrong interface. This is for jb4. Not stage 1.
Car: F10 M5
Default 08-07-2015, 07:08 AM
Thanks Gary for your response. I thought this was the case but Stage 1 interface doesn't connect and per the install guide, I am to use JB4 interface. See note below straight from their install guide.
If your box says "n63" in marker on it (and has //3 after the firmware date) then use the Stage1
interface. If your box says "n62-2" in marker on it (and has //4 after the firmware date) then use the
JB4 interface.
Default 08-07-2015, 12:55 PM
//4 indicates a G3_V2 board. So interface looks correct. What happens if you enter say 5.0?
Car: F10 M5
Default 08-07-2015, 03:26 PM
Terry, same thing happens with 5.0. It reduces I believe by .6. I am not in front of my computer but I found that this happens with any value I put in that field.
Ill give it a shot again tonight with 5 and see what value is returned.
Car: F10 M5
Default 08-08-2015, 03:16 PM
Terry,
I set it to 5.0 and once saved, it reduced to 4.3. I tried doing 5.1 and it reduced to 4.4.
It happens if I go up/down in values
Tried this on two different Stage 1 boards.
Car: F10 M5
Default 08-11-2015, 08:49 AM
Terry,
Any suggestions?
speed808ix speed808ix is offline
Car: F10 M5
Default 08-11-2015, 09:06 AM
Had this happen to me, I just set it higher all the time.
Car: F10 M5
Default 08-16-2015, 06:24 AM
I picked up a windows tablet for my car and noticed that when I change the values, it stays now. The issue must have been with my other computer. Glad it's corrected.
Thanks everyone for help
f10chris f10chris is offline
Car: F10 M5
Default 03-06-2016, 06:25 PM
JB4 interface.
My box just says 63-2 on it and can not get any firmware installed with the BMS cable and i did mine the exact way the instructions say and now can not upload a firmware to the box. any ideas?
Track Master's Avatar
Car: 135i, 2010, N55, DCT
Default 03-12-2016, 05:11 AM
Can you post link for the firmware update?
,12.01@119.3, With Meth
,12.10@115 e85 + ISO
390whp@497 - 0.60 in 3.75sec
Default 03-12-2016, 11:17 AM
There are no Stage1 firmware updates.
Gatchek Gatchek is offline
Car: 2014 BMW 535
Default 07-06-2018, 04:27 PM
Hi Terry,
I just purchased the USB cable for my stage 1 (not JB4) for my N55. What are my options as far as what I can do with my stage 1? Is there an updated firmware now? The car has started to hesitate under medium throttle, so I figured it may be the stage 1, and wanted to see if there was a diagnosis I could run. Thanks.
Default 07-06-2018, 04:47 PM
This is an S63TU thread, not an N55 thread.
But there are no diagnostics on Stage1 other than to check boost levels. Would need a JB4 for diagnostics.
Car: 2014 BMW 535
Default 07-06-2018, 07:05 PM
My apologies. But thanks for answering anyway. Much appreciated.
adamdatar adamdatar is offline
Car: X5M
Default 07-23-2018, 06:41 PM
how can i download the Stage 1 Tune for S63tu?
Default 07-23-2018, 07:05 PM
There are no Stage1 firmware updates, so nothing in any of these threads applies to Stage1.
ssgm1x ssgm1x is offline
Car: bmw 535i
Default 10-24-2018, 10:41 AM
Is there a manual or user guide for the Stage 1 unit. I was unaware of the interface. F80 M3
Default 10-24-2018, 11:40 AM
This thread is pretty old.
The Stage1 systems can have boost set between 0-4psi, it's already set to 4psi on //M models. You could technically set it to 5psi but generally a JB4 and its fuel control, CANbus, and advanced features are required for those levels.
dylonz dylonz is offline
Car: M6
Default BMS Stage 1 - S63TU M5 - 07-01-2021, 10:18 AM
Hey Terry,
Does the BMS Stage 1 tune for N63 work with the S63? Your website shows it as two different products, but this listing shows the BMS stage 1 will work on either. Any firmware updates needed?
https://burgertuning.com/collections...cts/n63-stage1
