(#1026)
Default Today, 11:26 AM
My ideas aren't too bad, right?
Yes this worked out nicely.
Default Today, 11:27 AM
Originally Posted by k8stinger_gt2
terry can u see if everything seems right
1. is map1 on 91 2nd, 3rd, 4th gear
2. is map5 e30 mix 4gallons rest 91 gear 2-4
3. is map5 e30 mix cruising
Looks OK to me. Any issues?
washguy washguy is offline
Car: gt2
Default Today, 06:10 PM
Payam's always has the right ideas......Right? ......Wash
Car: Stinger
Default Today, 09:36 PM
Originally Posted by Allmanb
Not sure if the torque convertor is cabable of that much slippage or can handle the heat generated from it. I'd think if we can get the ecu to not close down the throttle on launch and bring boost up it could launch fine at 2,000rpm. If i hold mine it has went up to 2,200 but it will start spinning the rear tires (even with it being awd).
One thought i had was to have the jb4 trick the ecu speed reading when in launch mode so that once the brake is let off the ecu thinks the car is over 10mph and will go full throttle. From my logs it seems after 10mph is when the ecu lets the car go full throttle. But i still don't hit full commanded boost until 4th. Sometimes 3rd gear but not very often.
I had this exact thought today. Logs show TPS is restricted till rolling about 8-10mph. If JB 4 could temporarily convince the ECU that the wheel speed is safe for full torque and pin the throttle to 100% would be grand indeed!
