M@rk's Avatar
M@rk M@rk is offline
Car: RHD E82 135i
Default Stage 1.5 turbo upgrade tuning - 08-09-2018, 05:32 AM
Hi Gents
Could you please review these logs please
Mods Are as follow:
jb4 (Race BEF)
Stage 1.5 turbo upgrade(Same as rb ones)
2' Inlets +Dci
Er charge pipe
Full exhaust
5' Cooler
dv's upgraded
91 octane fuel
cm14 single wmi
30% ethanol
bms Oil catch can
3.5 bar map sensor
These runs was done with 100% meth , no Ethanol content was added yet , fuel used 91 octane.
Map 6 felt good map 3 not so good as if it takes time to build boost there is a delay.
Current
BMW E82 135i N54
Stage 1 turbos,Inlets,5'' FMIC,Dci,ER Charge pipe,Forge dv,VRSF Down pipe,Full exhaust (Straight Pipe),Jb4,Alpina B3
Previous
BMW S1000RR
Default 08-09-2018, 01:48 PM
Logs look okay in general but It looks like you might have had air in the system. Meth flow takes a bit to reach 100% and your boost target is low at that point as well until it gets back up. I'm sure if you did a few runs on map 3 it would be just as quick.
M@rk's Avatar
Car: RHD E82 135i
Default 08-10-2018, 02:48 AM
I have noticed this as well I have primed the system numerous times it is still the same delay , as if there is no power/boost and only in high rpm i get boost all of a sudden not gradual boost .
What else could it be?
Also map 6 it seems like its over boosting should I be worried?
Current
BMW E82 135i N54
Previous
BMW S1000RR
M@rk's Avatar
Car: RHD E82 135i
Default 08-13-2018, 03:16 AM
Here is another log in map 3
Current
BMW E82 135i N54
Previous
BMW S1000RR
M@rk's Avatar
Car: RHD E82 135i
Default 08-28-2018, 01:10 AM
Hi Guys
Last night I made some more logs from map 1 till map 7
Could you please review the logs , 91 octane fuel + meth .
Thanks in advance
Current
BMW E82 135i N54
Previous
BMW S1000RR
Default 08-28-2018, 10:17 AM
Looks very strong man! Once that meth kick on you can see the trim just drop.
