Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default JB4 Mobile Server Maintenance Dec 1 2019 - 12-01-2019, 10:46 AM
I'm working on some updates to the server today so you may see some issues such as an inability to login over the course of the day. I doubt most of you will see any problems, but wanted to give everyone a heads up just in case. I'll report back here when everything is done.
Car: 2008 135i
Default 12-01-2019, 10:58 AM
That went quite a bit better than expected so the servers should be back to normal now.
Bbelstad's Avatar
Bbelstad Bbelstad is offline
Car: 08 E60 535i
Default 12-01-2019, 12:02 PM
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
barkietrin7 barkietrin7 is offline
Car: renualt
Default 06-12-2020, 01:15 AM
However all the components around it are complete ****, or they don't last much miles. I feel this engine puts way more stress on all these components then originally designed too.
I regret not doing an oil analysis from Blackstone lab before replacing all the components . I would be so pissed off when I finally finish replacing everything around my engine just to find out my engine is on it's way.
Parts replaced since I bought a 335i E90 sedan .
turbos oil pan gasket , oil filter housing gasket,valve cover gasket
"extended warranty paid for those turbos and gaskets "
water pump and thermostat serpentine belt and pulleys New DME ,fried the mosfets on mine due to MHD and having the old msd80 DME. coil packs and sparkplugs all shocks and struts radiator vacume lines starter alternator transmission solenoid valves and various valvebody seals
oh yea and I think my fuel system is showing signs of cramping out
also my IBS battery sensor is messing with my oil level readings
and still have a stock charge pipe
today will install aftermarket oil cooler my oem oil cooler lines are leaking
Edit/Delete Messageusps tracking showbox speed test
