Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default Rev 3.7 Connect Kit App Compatibility Updates - 05-01-2020, 10:44 AM
Hey guys we are releasing app updates for Android and iOS which includes some necessary compatibility updates for our new Rev 3.7 Connect Kits.
If you have one of these kits you will simply need to install the latest app build from the links below, hit the 'Connect' button, then follow the on-screen prompts.
For Rev 3.7 customers using the new update, JB4 Firmware Updates are just as fast as a direct USB connection when using an Upload Timeout value of 10. Rev 3 and Rev 3.6 customers will NOT notice any speed differences.
***Updated 06/04/2020***
**This should be one of the last Rev 3.7 firmware updates necessary as I believe I've worked out most of the bugs.**
This requires at least app build 2.4.4 (9375) for iOS or build A328 for Android.
These updates are now live for iOS and Android in the App Store/Google Play.
whytiptoe whytiptoe is offline
Car: 2019 Kia Stinger GT2
Default 05-06-2020, 08:50 AM
So this testing is for the new bluetooth module that connects to the JB4 and your phone, correct?
Car: 2008 135i
Default 05-12-2020, 06:40 AM
Yes. I'm finishing up one more update for the Rev 3.7 kits which should fix all the remaining bugs and as an added bonus DRASTICALLY improve JB4 Firmware Update times. I have it functional on my end and will be doing extended testing today to make sure I handle most of the different use-cases. If testing goes well then I'll have new beta versions for iOS and Android ready for users to try.
Car: 2008 135i
Default 05-14-2020, 07:53 AM
We are beginning extended testing today and if all goes well will have a beta ready tomorrow.
With the Rev 3.7 kits using the upcoming app versions, firmware updates can be just as fast as the direct USB connection.
Car: 2008 135i
Default 05-14-2020, 04:45 PM
The Android beta is live right now. iOS is uploading so I'll post the link for it once complete.
Car: 2008 135i
Default 05-14-2020, 06:31 PM
The iOS beta is now live as well. Thanks for your patience while we made these vital updates!
dannyq2 dannyq2 is offline
Car: 2016 340i Xi
Default 05-15-2020, 07:55 AM
Would you like us to update if we have 3.6?
Car: 2008 135i
Default 05-15-2020, 08:04 AM
Shouldn't really matter too much for non Rev 3.7 customers, but you're more than welcome to update if desired to use the new Firmware Update Interface with signal strength indicator.
Car: 2016 340i Xi
Default 05-15-2020, 08:20 AM
Cool I will do and test this combo for you.
MurlinatoR's Avatar
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 05-15-2020, 07:20 PM
I have the old BT kit and the update to v17 took as long as it did in the past, maybe a tad longer.
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
Default 05-15-2020, 09:32 PM
You'd need to drop timeout delay to 10 for the fastest possible upload time, if your device has a strong enough signal to run it.
Car: 2008 135i
Default 05-16-2020, 07:40 AM
That's because the speed improvements aren't in reference to the old kits (Rev 3 or Rev 3.6). The speed up is only for Rev 3.7 customers.
bosaad bosaad is offline
Car: Kia Stinger
Default 05-16-2020, 01:07 PM
Does Rev 3.7 support Bluetooth 5.0?
Jovanyy01 Jovanyy01 is offline
Car: 2011 135i n55
Default 05-16-2020, 06:27 PM
I updated the jb4 app on my iphone everything works fine until i try to read codes.
Invalid read. Please try again
Stock 2011 n55 135i
Jb4 stg1
Vrsf cp
Car: 2008 135i
Default 05-17-2020, 06:15 AM
Yes, the chip supports most of the features of BT 5.0. The 4.2/5.0 speed increase can be seen mainly when updating the Rev 3.7 kit OTA as that whole process usually takes less than 20 seconds.
These speed increase is also what allowed the dramatic improvements to the JB4 Firmware Updates for Rev 3.7 customers.
We'll check into it ASAP.
HerrCupra HerrCupra is offline
Car: Cupra ST 300 4Drive
Default 05-20-2020, 05:38 AM
Will there be an upgrade path for existing BT kit users? I'd love to be able to update firmware faster, but would have a hard time justifying the full price cost.
Car: 2008 135i
Default 05-22-2020, 08:56 AM
Maybe. We'll evaluate a few options here over the coming weeks.
Default 05-22-2020, 11:07 AM
Awesome, thanks in advance.
I imagine things are well out of the beta stage by now, but I'm willing and able to help however I can if not
wonderboy's Avatar
wonderboy wonderboy is offline
Car: bmw E91 N55 335i
Default 05-24-2020, 04:19 AM
How can i see which connection I have?
2011 n55 E91
Down pipe
Jb4 stg2
Charger pipe
5'' intercooler
Air inlet
Brant Yu Brant Yu is offline
Car: F31
Default 06-02-2020, 11:51 PM
Would you please check the BT kit Rev. were sold in PO# BMS91611 ?
Car: 2008 135i
Default 06-04-2020, 08:40 AM
2011 n55 E91
Down pipe
Jb4 stg2
Charger pipe
5'' intercooler
Air inlet
It says on the actual Connect Kit.
Not sure what this is in reference to. Email the applicable party for help troubleshooting.
Ralonso Ralonso is offline
Car: 2017 911 4s
Default 06-04-2020, 12:51 PM
Dmac,
i updated the app yesterday and then got a check engine. i cant read the codes now. every time i try it gives me an invalid read and i cant delete either. Car seems to be running fine.
Car: 2008 135i
Default 06-04-2020, 06:09 PM
Originally Posted by Ralonso
Dmac,
Please email into support3@jb4connectkit.com for help troubleshooting.
Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default updated app to version 3.7 questions - 06-09-2020, 09:30 AM
I updated the app for my iPhone, yesterday. I do like the improved firmware download methods, but...I am unable to save revised user adjustment settings, and the logs are all combined in some weird file number. How do I get back logging each WOT runs with their own file name time etc.
Alex
2020 330iX auto sport w/M track handling, JB4 ; 93 octane; Honda S2000; Ninja Z1000.
