T52's Avatar
T52 T52 is offline
Car: 2016 BMW 340i xDrive
Default Map Review - 11-02-2020, 09:23 AM
Please review attached maps on a '16 340i xDrive. I have about a 50/50 mix of 93 and 100 octane in the tank. The file is a combined three runs ... the first two in Map3 the last one Map 2. Trims are high on Map 3. Do you see any adjustments I should make?
Also ... in Map 3 I felt a slight hesitation on gear changes. In Map 2 they went away. Causes?
My 60' times need definite improving from 1.97. Any readers suggestions on best launch method? Tried launch control but actually have better results without using.
Thanks guys!!
Default 11-03-2020, 09:15 AM
EWG connector on this or not? Log itself looks OK but adding in EWG would be useful I think!
T52's Avatar
T52 T52 is offline
Default 11-03-2020, 11:25 AM
Hi Terry! I do not have the EWG connector installed. If you think it'll help I'll proceed and install one.
Default 11-04-2020, 02:28 PM
It's worth adding in
T52's Avatar
T52 T52 is offline
Default 11-05-2020, 06:26 PM
Thanks Terry!
I decided to go ahead with the EWG connector and also go forward with the MHD back end flash map. After I install the EWG connector should I contact you on a starter flash map? Or just go ahead and load the RACE BEF and perform some logs?
Default 11-06-2020, 05:11 PM
Load up RACE to start and log!
T52's Avatar
T52 T52 is offline
Default 11-15-2020, 03:51 PM
Hey Terry! Finished installing the EWG Connector and MHD BEF. Attached are two logs using RACE BEF ... one on map2 the other on map 3. These runs are using 93 octane fuel in the tank.
Honestly ... I really didn't notice much of any improvement in performance and my Dragy data shows no improvement either.
Interested in your thoughts on how they look.
Thanks in advance!
T52's Avatar
T52 T52 is offline
Default 11-20-2020, 04:22 PM
Hi Terry! can you take a look at the attached logs and let me know your recommendations?
Default 11-20-2020, 04:40 PM
Set duty bias to 50 across the board, PID gain to 20, and relog!
T52's Avatar
T52 T52 is offline
Default New Logs - 11-21-2020, 04:44 PM
Here are new logs with duty bias at 50 and PID gain at 20. One is at map 2 and another at map 3.
The car felt more responsive and stronger though the Dragy times were very similar as the last runs made.
Default 11-21-2020, 05:23 PM
Logs look clean. Try a run on map4 next for comparison's sake.
T52's Avatar
T52 T52 is offline
Default 11-21-2020, 05:59 PM
Thanks Terry for your quick feedback!! I'll give map4 a go and let you know the results.
T52's Avatar
T52 T52 is offline
Default New Map4 log - Yesterday, 06:04 PM
Hey Terry! Attached is a new log trying Map4. This is still only using 93octane.
I've been comparing my Dragy results on 1/4-mile runs and this is a quick rundown:
11/26/19 - Pre-MHD, 93 octane, older firmware, Map2 - 12.31@110.93
11/01/20 - Pre-MHD, 50% 100octane, latest firmware, Map3 - 12.28@112.59
11/21/20 - MHD & EWG, 93octane, latest firmware, Map3 - 12.38@112.83
11/28/20 - MHD & EWG, 93octane, latest firmware, Map4 - 12.33@112.06
I was anticipating better results. Do you have any suggestions given the latest logs?
Thanks again!!
