Dwifter Dwifter is offline
Car: 2008 335i
Default O2 codes and running lean - 09-27-2021, 09:20 PM
I have some codes that I cant seem to figure out the cause of.
2C2B-DME: Oxygen sensor before catalytic converter: system check
2C2C-DME: Oxygen sensor 2 before catalytic converter: system check
2C32-DME: Lambda control 2
2C31-DME: Oxygen sensor control
All i have for mods is a JB4 on map1 and an intercooler. I've replaced the o2 sensors, just put new index 12 injectors, it needed a new fuel pump, I've replaced the high presure fuel pump 1k miles ago, and it has newer plugs and coils.
The afr seems really lean to me at wot (hangs at 15.1 on both banks) and the JB4 keeps kicking on to the safety map. Been trying to chase this down for 2 months now as I need to get emissions done on the car soon. A really bad misfire just came up on cylinder 6, so I won't be able to get a log done tonight. Does anyone have any suggestions to what might be causing these?
Car: Evo VIII
Default 09-28-2021, 11:40 AM
Please switch to map 4 and upload a log. Thanks!
Car: 2008 335i
Default 09-28-2021, 11:56 AM
Won't be able to get one posted until tonight.
What kind of data would you need? I use the JB4 mobile app for logs and stuff.
Car: Evo VIII
Default 09-28-2021, 01:53 PM
For proper review and the JB4 to adapt, please do logs in 3rd to 4th gear from 2k rpms to redline at wide open throttle. Thanks!
Car: 2008 335i
Default 09-30-2021, 01:45 PM
Had some stuff come up so I wasn't able to do this sooner.
a_log.csv
Car: Evo VIII
Default 10-01-2021, 08:34 AM
Can you please send a picture of your JB4 board? Also, set user adjustment settings back to default values. Set your 6 cylinder timing to 5. Make sure to set your 3rd gear max boost back to 0 instead of 4. Once those changes have been made, go ahead and set another log in 3rd or 4th gear from 2k to redline at wide open throttle with traction control off. Thanks!
Car: 2008 335i
Default 10-01-2021, 04:08 PM
a_log_2.csv
It won't let me upload the image, but there was a lot of corrosion on the board around the capacitors.
Car: 2008 335i
Default 10-01-2021, 06:43 PM
Originally Posted by Dwifter
Attachment 104121
I took the jb4 off to look at the board. Well driving it around the codes haven't come back and my car feels like it's running better. Maybe the jb4 was just ruined?
Car: Evo VIII
Default 10-04-2021, 09:31 AM
Looks like you were running a pretty old board, so if there is corrosion as well, I'd definitely suggest replacing the board.
https://burgertuning.com/collections...=2580727595032
Car: 2008 335i
Default 10-04-2021, 09:43 AM
Been running the car all weekend without the jb4. Not a single issue has come up. I'll look into replacing the board. Thanks
