Edu Vianna Edu Vianna is offline
Car: BMW 320i MSport
Unhappy New firmware update problems - 06-24-2020, 04:46 PM
I have N20 BMW 320i MSport 2018 ActiveFlex in Brazil with JB4 EWG Cable with JB4 Wireless Mobile Smartphone kit (2.4.4) on Iphone 7 IOS 13.5.1 and Map 6. After update to the new firmware N20_OBDII_EWG_7 some times the gauges is freeze. I disconnect and reconnect the app e the gauges back to work again. I was check all connections and looks be ok. Another point, some times during a log, JB4 change from map 6 to map4. After seconds, return to map 6. No codes and nothing like wrong. It is appear in the log parameters, but we don't see nothing what was exceed the limits. I was reinstall the firmware but the issues remain the same. I have thinking to make a downgrade to the old firmware but a cant find it anywhere. The app don't show anymore the lasts firmware.
Somebody can help? Therry, Can you heard me?
Tks guys!
Default 06-25-2020, 07:40 PM
I see you emailed in, get your issue sorted? May need to turn on CANbus slower speed by turning on options bit7.
Default 06-25-2020, 08:51 PM
Hi Terry, thank you for the answer! Bi7 on may solve map change or freezing the gauges? Tks
Default 06-25-2020, 09:12 PM
I mean gauges of the JB4 Mobile app!
Default 06-26-2020, 10:20 AM
Hi Terry, Bit7 enabled did not solve the problems. Nothing changed!
Another suggestion? Reinstall the firmware update?
Tks
Default Settings - 06-29-2020, 04:12 PM
Hi Terry,
i attached the settings i use on map 6
Tks!
Default 06-29-2020, 08:41 PM
The JB4 log of the problem would have all the settings in it as well. So that is all we need.
Default 06-30-2020, 02:01 PM
Here is the logs with map change from 5 to 4. Default Settings.
Default 06-30-2020, 02:02 PM
Here the log with no map change. Default Settings.
Default 06-30-2020, 05:11 PM
OK email me and I'll send you a firmware update to test here. terry@burgertuning.com
