ruby88 ruby88 is offline
Car: X1
Default JB4--2012 E84 X1(N20B20A) - 03-12-2020, 09:00 AM
I am the X1 - N20 engine of E84. After replacing the large turbine, I hope to get a higher boost value when installing jb4. However, in map6, I can only set 25psi, and I hope to have new special firmware to make me reach the set value of 30psi.
notebookboy's Avatar
notebookboy notebookboy is offline
Car: 2013 Z4 20i
Default 05-16-2020, 09:08 AM
Is your X1 20i or 28i?
JB4 has +10PSI stock ecu limit for the N20 version.
If you got a 20i, the max ecu psi is around 9 to 10. You will get max 9 to 10 +10=19 to 20 psi no matter on which map.
If you got a 28i, the max ecu is around 15 to 16. You will get max 15 to 16 +10=25 to 26 psi. Even if you set 30 PSI in map6, you still get 25-26 psi max.
Default 05-16-2020, 07:01 PM
For the X1 we'd need to rescale the system to allow up to 36psi. But are you running a flash tune? Meth system? It will take more than just JB4 to safely tune the N20 to those power levels.
Car: 2013 Z4 20i
Default 05-17-2020, 06:27 AM
Hello Terry,
Hope all is well.
Is it possible to overwrite the +10 PSI limit over stock ECU for Z4 E89 N20 PWG 20i?
The stock ecu is around 8 PSI. It seems possible with TMAP=1. I did a pull to 3rd gear. The ECU PSI is 8.9, actual boost is 20.2. The Ign isn't good due to the bad fuel(91oct/95ron) and hot weather though.
Is it correct to set TMAP=1 on a PWG N20 with a PWG firmware?
Default 05-17-2020, 08:08 AM
It's just not safe to change that safety at this time. For higher boost levels get a lower boost flash loaded. We'd write one but MHD has not released tools yet for it.
Car: 2013 Z4 20i
Smile 05-17-2020, 09:35 AM
Well noted. Thanks a lot for the reply.
Have a nice weekend.
It's just not safe to change that safety at this time. For higher boost levels get a lower boost flash run. We'd write one but MHD has not released tools yet for it.
Car: X1
Default 05-28-2020, 08:50 AM
Hello Terry,
Hope all is well.
I am 20i, but I have changed the big turbine. How can I set the pressure to 36psi? In map6, the maximum setting is 25.5psi
Also, which new version of X1 firmware of E84 can be updated?
