(#1701)
freeware freeware is offline
Car: bmw
Default 08-30-2019, 10:02 PM
waiting for firmware update))
not all n20 engines have exploded yet
ahah)
dannytanky dannytanky is offline
Car: F30
Default 09-07-2019, 06:23 AM
Noob question. Friend wants to sell me his B48 JB4. Can this be reflashed with N20 firmware to be used in my F30 328i? Any other difference between the two JB4 models? Any advice appreciated.
Default 09-09-2019, 10:09 AM
No, totally different stuff.
ocr4m ocr4m is offline
Car: Bmw 320i n20
Default 09-10-2019, 07:39 AM
Hi guys, yesterday I updated the Jb4 firmware to version N20_OBDII_EWG_6.hex (13/6//5) and now the car is not doing so well and with the same performance as the penultimate fw on map 6. I wonder if anyone can make it available the firmware version N20_OBDII_EWG_5.hex (13/5//5), either by private message or e-mail.
I appreciate any help.
Default 09-10-2019, 11:40 AM
Post a log in the support section so we can evaluate it.
Car: Bmw 320i n20
Default 09-10-2019, 02:57 PM
Done Bro! https://www.n54tech.com/forums/showt...523#post645523
liveevil liveevil is offline
Car: F34 320i
Default 01-20-2020, 03:46 PM
Hi when I read code, it says “c@tless d0wnpipe detected”. No CEL and is located in USA
Is this normal? I have a high flow down pipe from ER.
tringuyen7757 tringuyen7757 is offline
Car: 2014 BMW 528i
Default BC Button and Gauge sweep not working - 02-17-2020, 11:26 PM
Hey guys. I have a 2014 528i with the JB4 and connect kit. I am on latest firmware, but I donít get the gauge sweep and the BC button doesnít work. Is there a way to fix this?
Default 02-22-2020, 02:49 PM
For 5 series try setting options/FUD bit1 on in the JB4 mobile app.
Frank98K Frank98K is offline
Car: BWM X3 F25 N20AB20A
Default 05-02-2020, 02:33 PM
Hello, could you please tell me where the firmware of BMW N20B20A has gone? I didn't find it in the log and website. Could you please send me a copy
Default 05-11-2020, 03:42 PM
See link and video in the bottom of the first post.
notebookboy's Avatar
notebookboy notebookboy is offline
Car: 2013 Z4 20i
Default 05-13-2020, 05:19 AM
Do you mean the X1 Z4 N20B20A firmware? Seems that it's gone.
ruby88 ruby88 is offline
Car: X1
Default 05-28-2020, 11:03 AM
How to download the X1 firmware of E84 for N20 engine?
Email:Ruby88@163.com
Car: X1
Default 05-28-2020, 11:05 AM
Have you received the X1 firmware of E84 for the new N20 engine?
Can I have a copy?
email:Ruby88@163.com
mdesq9 mdesq9 is offline
Car: 2013 BMW n20 f30
Default Firmware version 13/7//5 - F30 N20 EWG - 05-28-2020, 03:10 PM
I just updated my JB4 firmware to N20_OBDII_EWG_7.hex - alternatively, firmware version 13/7//5. Prior to this updated I did not have any issue with engine malfunction/limp mode and other various codes within the JB4 app and my check engine light was deleted. After the update, my check engine light is on and I am getting the following codes: 123412 electric waste gate, stop learning: stop position (waste gate closed) not found; 123401 Wastegate Learning Stop During c@t Heading Cycle; 120408 Reduced Power mode; and 180001 c@t ******** detected. I have tried to redo the update and the problem persisted. Please let me know what I can provide to help resolve this issue. Any advice is appreciated!
Krzysiek Krzysiek is offline
Car: BMW F31 320i N20 M/T 2013 EWG
Default 06-11-2020, 03:22 AM
I also tried to update my 2013 320i to N20_OBDII_EWG_7.hex and had similar problem. Lots of errors:
120408 reduced power mode
121001 TMAP sensor, short circuit to B+
104401 MAP sensor, intake pipe, electrical: short circuit to B+
119404 Rail pressure sensor, signal stuck
CD8F01 Intelligent Battery Sensor, LIN communication: Timeout
11A002 Fuel pressure below target
119001 Rail sensor short circuit
Couldn't start up engine. I came back to 6.hex and everything was ok as before. I have upgraded Wagner intercooler and intake with cone filter and exhaust modified. OEM down pipe.
Default 06-11-2020, 05:37 AM
Eventually, my concerns were validated only by Terry. Terry said it appears there is a problem with the electronic wastegate logic. Hopefully, a fix will come soon. It is good that you were able to go back to a previous firmware version.
Brant Yu Brant Yu is offline
Car: F31
Default 06-11-2020, 10:29 AM
I also had above 2 issue after updating to EWG_7, but luckily I was able to delete these 2 error code successfully.
Do you install the Go Fast Bits Diverter Valve (T9357 DV+) ? Wondering whether or not this thing impact how the electronic wastegate logic works.
Default 06-11-2020, 10:45 AM
No I have not - I was considering it as I have already replaced my exhaust manifold and new oem wastegate in the past. I am wondering anyone's experience with a new diverter valve.
Car: F31
Default 06-22-2020, 12:53 AM
Thanks for the reply. DV+ is quite popular for N20 engine, it's worthy of investment which helps you hold the extra boost JB4 feed DME.
Default 07-02-2020, 10:07 AM
Updated the N20 EWG firmware with new BETA for better EWG control. Could use a few logs to evaluate it!
echacon echacon is offline
Car: Cooper S F56
Default 07-10-2020, 09:21 AM
Hello, recently installed a JB4 with flex, ewg and OBD cables in a Z4 - N20 engine. What firmware should I use? I downloaded HEX_7 (in n20 engine session) and I'm using it on map 2, but the map selector doesn't work. Thanks.
Default 07-11-2020, 02:37 PM
If using OBDII then use the normal firmware but won't have in dash controls. You'd need ECU posi-tap attached CANbus and Z4 specific firmware for the in dash controls.
Car: F34 320i
Default 07-24-2020, 08:13 PM
Hi Terry,
Is that the ewg6_T4 file (or 13/6//5)? I am currently on this so if want to know what the better ewg control would mean? Thanks
2020veloster_n 2020veloster_n is offline
Car: veloster n
Default 07-27-2020, 05:39 PM
Terry I removed my JB4 from my veloster N. can I use the same JB4 on my 2014 F30 2.0 Turbo BMW. do I need a new harness or are they same.
