(#476)
Cloner Cloner is offline
Car: MY2014 328i
Default 01-16-2014, 02:48 PM
The JB4 automatically deletes any non-serious codes when enabled. So you are good to go.
Thanks for the reply Terry,
And sorry if I put this question in the wrong area of the forum but what is considered a "serious code" that would not be deleted automatically?
Cloner
Default 01-16-2014, 06:09 PM
Cloner
Codes that show a check engine light in dash. For future support related questions use the support section.
kendroz kendroz is offline
Car: BMW F30 328i
Default 01-16-2014, 07:26 PM
Greetings Terry!
I'm planing on going to the track on saturday to check my stage2. With a KN filter and stage1 running 100 Octane fuel i managed 13.5 time. Now I have the paper filter and the stage2 so do you recommend me to run on 93Oct or 100Oct to the test? I remove the KN filter because I think it did nothing to the car.
Take Care
Car: BMW F30 328i
Default 01-19-2014, 07:00 PM
Thank's for your reply Terry, will do your recommendations.
Default 01-19-2014, 09:05 PM
Originally Posted by kendroz
Greetings Terry!
Take Care
If the 100 octane is racing fuel, you can try map 2 and map 7 to see what works best for your vehicle. I'd also raise the boost safety setting to 24.0.
The Voice The Voice is offline
Car: F30 320i M Sport
Default 01-22-2014, 02:18 AM
Terry,
What's the update on the latest hex file?
GuMMiBaEr's Avatar
GuMMiBaEr GuMMiBaEr is offline
Car: F31 328XI N20 03/2013
Default 01-22-2014, 02:26 AM
Aaaawwhhh, there is a new hex file! Nice!
Thanks "The Voice" for that info!
Why didnīt we get any information and/or changelog for this new file?
F31 | 328XI | N20B20A | 03/2013 | JB4 Stage 2 | Map 2 | FF Wires | 4" DP | Wagner Comp FMIC | Pipercross drop in | OCC | KW V2
Bid assistance in Germany for troubleshooting, coding, alpina flash, ecu tuning etc.
GuMMiBaEr's Avatar
Default 01-22-2014, 09:10 AM
So...1hr ago i updatet to latest hex firmware "6"
But could not found any changes :-/
wmandra wmandra is offline
Default 01-22-2014, 12:52 PM
Terry,
For those of us running stage2 with the electronic wastegate, is it safe to remove the MAF connector and solenoid connectors from the JB4 harness? Going to be upgrading to the new JB4 case and installing flex-fuel wires in the next day or so and would be nice to clean up the other unused connections.
Bill
Default 01-22-2014, 10:08 PM
Originally Posted by wmandra
Terry,
Bill
I would avoid it, because we may reuse those connections in the future as part of the electronic solenoid control. You can zip tie them together or maybe remove them from the conduit and zip tie them closer to the box to clean things up if you prefer.
Originally Posted by The Voice
Terry,
Oh just some minor internal changes. Fixed a bug with code reading on more than 2 codes, added some test options, etc. Nothing really to justify a user update.
Default 01-24-2014, 11:00 AM
Thanks Terry.
Also, do any settings have to be changed after installing the flex fuel wires? Or is it just connect up per the instructions and start adding E85?
GuMMiBaEr's Avatar
Default 01-27-2014, 10:27 AM
Hello.
Last tuesday, i installed the OCC.
Today, i'd like to take a first look in the can, how much oil is in there.
But it's not possible to get off the can. When i unscrew the can, then there is not enough space under it to get it down. I hope you unterstand what i mean...
Here is a picture of my install:
Default 01-27-2014, 11:05 AM
You would remove the bracket and swing it out. Normally you check it every 3-6 months.
activ3 activ3 is offline
Car: X1 N20
Default 01-27-2014, 11:57 AM
Is the OCC X1 compatible?
Also, I just ran my X1 with electronic wastegate at the drag strip, with a JB4 in map 1, and put down a 13.9 @ 98.9mph which is about as fast as a stock N55 x1.
Car: BMW F30 328i
Default 01-28-2014, 08:24 PM
My 328i EW (electronic wastegate) with JB4 stage2 using map1 did 13.6 with 93oct fuel.
When hot 13.7 so see this http://www.youtube.com/watch?v=0hUZCAVEXfc
Next time I will switch to map2 per Terry recommedations.
Good time
GuMMiBaEr's Avatar
Default 01-29-2014, 10:19 AM
OilCatchCan After 8 days and around 200km (130mi)
I think that is to much, to look inside after 3-6month?!
seroga1986's Avatar
seroga1986 seroga1986 is offline
Default 01-29-2014, 04:26 PM
Yes it is too much. Mine does the same thing. It is fuel mixed with condensation. My car is currently at the dealer getting looked at. Oil catch can would be full 300 miles of this stuff. Obviously not normal if this stuff is getting into our oil. Check out my thread from a while ago that i posted.
http://www.n54tech.com/forums/showthread.php?t=23044
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
Seraphblade@SG Seraphblade@SG is offline
Car: BMW F30 328i
Default 01-29-2014, 05:32 PM
Now the question will be, do we need an oil catch can?
This is fuel and water, which will be no issues if passed directly back into the engine without going through the oil catch system...
Looking at both pictures, it seems that there isn't much oil or sludge other then fuel and water... Which is good right?
The occ for my previous cars never caught (or at least so significant) fuel and water... Maybe with additives (valve cleaners) to the fuel, they might actually work even for the n20 engine? Since some of the fuel will still be passed through this bypass back.
seroga1986's Avatar
Default 01-29-2014, 05:46 PM
I am catching 1/4 of catch can in 10,000 miles on my n54 135i and its dark oil (blowby) no fuel. I am waiting to see what dealer will say about the n20. Also dont you think this fuel/water will get trapped at the bottom of intercooler?
2008 135i Sport 6at
Car: BMW F30 328i
Default 01-29-2014, 07:20 PM
I dun think so... If I am not mistaken, it looks like this bypass gets back into the intake pass the intercooler...
In any case, I'll be getting my wagner competition IC next month... I'll update if there is any stuff inside the stock IC
Default 01-29-2014, 10:37 PM
Seems about normal for the N20. It seems to blow a lot of water condensation through there. Over time that will boil off and only the oil will be left in the can. Check it again in say a month and lets see how it looks.
GuMMiBaEr's Avatar
Default 01-30-2014, 12:04 AM
Ohh damn, i like this car everyday more less...
One problem with it after another...
I will check it the next time in 2 weeks, on weekend i do some longer trips not only these short trips at the moment.
I hope it gets better with longer trips
@seroga1986: When did you get your car back? Did, you really hink the dealer could found anything?
If i read your thread correct, there could be a reason for this in case when itīs cold and you did short trips.
So, did we wait for summer? And what to do in winter?
seroga1986's Avatar
Default 01-30-2014, 05:23 PM
I did not get my car back yet. The service advisor said that it doesnt sound normal for it filling up with fuel so much. Also i did manage to drive 300 miles on it without emptying it and yes it was full to the rim. The condensation actually got frozen in the OCC. And there was some fuel/oil on top that did not freeze. I just wonder if the intercooler is half full of this stuff too. The combination of winter and oil temps never reaching above 180° is filling up this catch can with condensation. But why fuel??
2008 135i Sport 6at
morkusyambo morkusyambo is offline
Car: 328i
Default 02-01-2014, 07:55 AM
Not sure if this is the right thread for this, but I wanted to give a shoutout to Terry and Jon. They patiently worked with me on a problem I had with the JB4 and ultimately went above and beyond to help me with their product.
Copyright Đ 2007 - 2020, N54tech.com
