jgklim's Avatar
jgklim jgklim is offline
Car: 2018 Honda Civic Sport
Default jgklim's JB4 Build - 02-25-2019, 03:34 PM
Hello JB4 community!
Very excited to be using this system. I've started this thread to document my journey/build with JB4.
I'll add to this thread content like photos, logs, and experiences as I go
Introduction:
2018 Civic Sport CVT, I won't elaborate on the cosmetics for now
From Canada, B.C.: which means the weather is either like this...
or this...
Mar 2019
I got a package in the mail...
Didn't get any pics of the finished install, but...
The intake is great! Really improves the engine and turbo sounds!
Throttle is definitely more responsive...as I mash it repeatedly
Default 02-25-2019, 06:21 PM
Awesome! Can't wait to check out your logs.
jgklim's Avatar
Default 03-03-2019, 08:07 PM
March 2019
Idle values look like this
Until I actually get some good pulls, here are some baselines for map 1:
1st - Idle, slightly warmed up
2nd - On and Off
If trim scaling is correct, idling at 35 is spot on at 0%, and in the 2nd log i'm dancing around 3-5% under load.
Question: Is there a parameter for CVT trans temperature?
File Type: csv 2019-03-03 15_47_16 (JLCVT)_Gear-0_Map-1.csv (17.4 KB, 154 views)
jgklim's Avatar
Default 03-06-2019, 12:59 PM
Short Pull in the artificial 3rd on CVT
File Type: csv 2019-03-06 08_07_17 (JLCVT)_Gear-0_Map-1.csv (8.2 KB, 137 views)
Default 03-07-2019, 09:54 AM
Looks normal to me.
jgklim's Avatar
Default 03-07-2019, 10:39 AM
Looks normal to me.
Thanks Terry, time to try Map 2
Odinist's Avatar
Odinist Odinist is offline
Car: 2018 Civic Si
Default 03-06-2019, 06:52 PM
I dig the engine cover, link?
Mishimoto intake, resonator delete, Vibrant 1040 muffler, JB4 tuner, Firehawk Indy 500 rubber, Lamin-X fog light covers, Xentec 35w 6000k HIDs, custom d20 shift knob, 20% tint, red "H" badges.
jgklim's Avatar
Default 03-06-2019, 08:48 PM
https://m.tb.cn/h.3DEPKuq?sm=285c4f
Try that, ordering from china can be a pain in the butt though!
Odinist's Avatar
Car: 2018 Civic Si
Default 03-07-2019, 09:42 AM
Holy crap, so that thing is only like three bucks in USD?? AWESOME.
jgklim's Avatar
Possibly It was 170 yuan for the cover when I bought it. I used superbuy.com as an agent and also purchased SEDAN seat covers to make the shipping more worthwhile. Cost me overall 450 yuan for both items, then duties
The sedan covers fit the rear bench, but not the back seat. It needs some trimming and adjustments
Default 03-07-2019, 10:35 PM
jgklim's Avatar
Default 03-09-2019, 02:55 AM
Intake updates
Having installed the intake first... I haven't gotten a chance to log with the stock intake.
It looks and sounds so good!
After about a week of using the intake and looking at logs, I think my trims1/trims2 are sitting a little high.
Correct me if I'm wrong:
If 25=0%, and 50=33%
Then each (1 trim unit) in the log is = (33%)/(delta25) = 1.32%
Map 2 Pull: My trims2 being 32 or 33 (+7/+8) means I've got about +9.24% to +10.56%. Feels high
Is this something that should be adjusted? Looking at the new SI intake and the resulting trims (spot on!), I wonder if I've done something wrong to get the lean trims.
A Type R on these forums is also getting around 25 for trims.
Edit: I wonder if this is due to "up to 10%" ethanol in the Chevron 92 I filled with
Attached: Map 2 pull - gotta start logging in lower RPMs
File Type: csv 2019-03-08 22_13_42 (JLCVT)_Gear-0_Map-2.csv (4.0 KB, 136 views)
jgklim's Avatar
Default 03-13-2019, 10:39 PM
Map 2 and LTFT
Pull in Map 2 - Seeking check before Moving to Map 3!
Following my previous inquiry - Found that after putting in some 94, trims went down
- Finding that when changes of fuel is detected, avg ign goes up. I suppose to adjust to new fuel
- It takes about a day or two (driving 30-50 km) to go back to 4.9
I figure this means half-filling tanks/filling more often means that the car has to adjust more often.
Ethanol does affect trims: making the car "think" to add more fuel
Next question: When to stop adding boost (Upping maps)? How can we be "safe" with the CVT? Is it avg_ign? Any other indicators? What about long-term?
File Type: csv 2019-03-12 07_55_01 (JLCVT)_Gear-0_Map-2.csv (7.2 KB, 169 views)
jgklim's Avatar
Default 07-01-2019, 11:00 AM
Ricky going fast Ricky going fast is offline
Car: 2017 Honda Civic sport hatch
Default 08-10-2019, 02:37 PM
Hi I also have a Civic sport CVt 2017 , I知 getting my JB4 installed Monday
With new springs and intake , so did you get the answer with how much torque
Or boost the CVT can handle ??? I知 new to this and not sure I値l be making my own maps , will map 1,2 and ,3 be ok , with out blowing my CVY or turbo are the presets safe .
jgklim's Avatar
Default 08-11-2019, 03:27 PM
I have no doubt the presets are safe. BMS also has a cvt which they developed with. That being said, I run map 3 most of the time and my experience has been positive. It's been about half a year, and no problems.
If you want to get supporting mods, an intercooler may help
Default 08-11-2019, 06:48 PM
Awesome! Thanks for the reply. Intercooler makes sense now that I think about it I知 in south Florida that would help a lot , think that will be next on my mod list Can稚 wait until the end of the day tomorrow
I知 making sure they are going to check my cars over all health it痴 a 2017
But have 57,000 miles on it all highway miles . Your hatch looks great
I have the white with black trim sport , I値l send you some pics and logs when I get the car back with it lowered Eibach Sportline Springs the k&n Intake also adding 20mm spacers to the rims and JB4 all tomorrow.Have a great week !
Default 08-11-2019, 07:56 PM
Our CVT is still pulling hard with zero issues. We switch between 91 octane map1 and E30 map3.
Copyright ゥ 2007 - 2020, N54tech.com
