(#1926)
wrcwia wrcwia is offline
Car: 2017 M240
Default 12-03-2020, 11:05 PM
Originally Posted by wrcwia
Hi Terry,
Am I able to test the DWP setting on map 2 as well...or are you recommending this option only on map 3, and map 4?
Terry -
Just wanted to see if you had time to answer my question above regarding testing the DWP for Map 2...is it recommended to try adjusting the DWP?
KnifeEdge87 KnifeEdge87 is offline
Car: BMW G30 520i 2019
Default 12-04-2020, 02:27 AM
Originally Posted by KnifeEdge87
DWP is "Default wastegate position" right ?
If we're not actually changing the wastegate position (as mentioned no EWG required) what's the JB4 actually doing when we change this setting ?
If we have the EWG harness, what does changing this setting do ?
Any info here?
VipinLJ VipinLJ is offline
Default 12-04-2020, 09:38 PM
Any info here?
I'd love to know too
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
Bobloblaw Bobloblaw is offline
Car: BMW G20 330i
Default 12-26-2020, 08:54 PM
Hi Terry. I've recently installed a JB4 on my 19 G20 330i (B48) AUS Spec. I ran Map 2 on a hot day (37c) and I think I could hear a little knock. I've followed one of your guides (another post on how to read logs) but couldn't see anything in the logs that would indicate it timing wasn't being heavily adjusted(since deleted)
I've done a couple of other WOT runs (below) in Map 1 & 2 @ around 28.5c ambient and just wanted to see if you (or others) can spot anything odd, or if it looks fairly normal.
Default 12-27-2020, 09:34 AM
Do a longer higher speed run so we can better evaluate timing advance under load.
Terry -
The BETA DWP feature if enabled is active on all maps.
Car: BMW G20 330i
Default 12-27-2020, 06:44 PM
I'm not too close to Mexico, so it's a bit tricky to do a decent run. Here's 0-130ish (km/h) WOT.
I also got a 101F01 Throttle valve opening angle pressure --ignore, tuner code on my way home. I did WOT in Map 2 up to 110ish km/h. No log from that event. Is this a tune flag for the dealer or something, or an actual fault?
rogbq rogbq is offline
Car: m235i
Default 12-30-2020, 02:07 AM
Originally Posted by Javi
Hello, I just tried to install to my 2018 X3 M40i the JB4 for N58 but the check engine light came on and came up with code 164020 Inlet camshaft sensor: Signal High.
I did the installation with the negative removed, per instructions.
Don’t know if its too new for the current firmware.
Please help!
What is the fix facing the same issue with 745
tmoffat86 tmoffat86 is offline
Car: 2007 335i Coupe
Default 01-16-2021, 10:55 PM
I just installed my JB4 in my 2019 M240i and when i go into the menu using the dash gauges the needles are both bouncing all over the place.
Any ideas how to fix that?
Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default Map 6 auto tuning - 01-21-2021, 07:54 PM
Does map 6 do auto tuning, and does ff 50 also turn this feature off for that map?
