Default New stock turbo dyno record, 4/25/13 - 04-25-2013, 01:05 PM
Had a chance to get our E92 manual back to the dyno today. We've recently replaced the clutch and added a meth kit.
Full mod listing:
JB4 G5 ISO
BMS back end flash -- "race" file
BMS *********
CPE intercooler
CPE chargepipe w/ tial valve
BMS DCI
BMS OCC
Spec clutch w/ steel single mass flywheel
BMS 2.2g meth kit w/ 80% ethanol / 20% water, CM12 nozzle
E40 fuel (40% E98, 60% pump 91 octane)
"Option2" inline booster pump
I'll post the log later but peak boost was ~20.5psi and we're running around 13 degrees peak advance on it. Overall car performed very well and we were happy to raise the bar on stock turbo performance a bit.
Attached is the dyno sheet and a photo of the car & Jon working the dyno software.
Tuned1M's Avatar
Tuned1M Tuned1M is offline
Car: AW 1M
Default 04-25-2013, 01:06 PM
Woah....nice job!
'16 LBB M2 in production
'11 BMW 1M sold
Milwaukee135's Avatar
Milwaukee135 Milwaukee135 is offline
Car: 2008 135i
Default 04-25-2013, 01:19 PM
Tuning Obsessed Central Oregon Engineer
08 E82 N54 (bimmerboost flash tuned by me)
08n54 08n54 is offline
Car: 2008 535xi
Default 04-25-2013, 01:28 PM
That's awesome, is that just map3 or 6?
drm916 drm916 is offline
Car: 08 335i
Default 04-25-2013, 01:39 PM
is the inline pump necessary? Or was it just added for the headroom? I am concidering it but havent decided yet. I normally run 93 but would love to do a 50/50 e85 fill sometimes.
Default 04-25-2013, 02:17 PM
We used to run the car on E50 only and the pump was needed. But for a meth setup most likely isn't required. The car has a 3.5 bar map sensor and we're basically running map 3 w/ a 85 additive. Not for the faint of heart but makes for a fun dyno day.
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 04-25-2013, 02:22 PM
You're just trying to break the fans so you have a legit reason to strap stage 3's on and get some fancy numbers with less parasitic loss than the slushbox, admit it! Sneaky sneaky breaking some records on the way lol. Nice looking wheels btw.
Default 04-25-2013, 02:29 PM
Wow...Crazy...so how does 21psi on stock turbos compare to 21psi on RBs?
Default 04-25-2013, 02:34 PM
Added the 461rw log to the first post. Looks like boost was 1/2psi less than I thought. Was just going by gauge in car as we did the runs.
This boost curve on RBs would be worth ~50rw more all else being equal. And the RBs would hold that much better at higher RPM.
albertc albertc is offline
Car: 2007 335i
Default 04-25-2013, 02:36 PM
Lol so I hop you can do this with rb but another 70 whp??
JB4 G5, DCI, **, IC, Del Cats, Walbro LPFP, Meth
Default 04-25-2013, 02:38 PM
With a similar advance curve and similar peak boost with RB turbos, we've done 520rw.
Car: 2007 335i
Default 04-25-2013, 02:50 PM
Afr looking great on that dyno, I would like to see this or even better with 100% e85, there is someone experimenting with the fuel rail in another post, I was running full e85 but went back to 50% cuz of misfires. Also with 100% e85 my clutch was slipping badly, probably making a lot more torque....
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 04-25-2013, 03:21 PM
Nice....very, very consistant.
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 04-25-2013, 03:56 PM
The N54 never ceases to amaze me! Great job Terry.
It would be cool to see those comparisons overlaid, anyone capable of doing that?
SaferTransport's Avatar
SaferTransport SaferTransport is offline
Car: e92 335i Coupe
Default 04-25-2013, 04:01 PM
Terry, why does Johns car make 30 more tq than me?
JB+RB=
Default 04-25-2013, 04:14 PM
Not sure, I'd have to overlay your logs to see. But on the RBs we've never gotten overly greedy with low end boost as they just burn up those ATs anyway.
Default 04-25-2013, 05:22 PM
Sure, here is a dyno from sranch335's RB turbos. MT with same mods basically. How does ~100rw at higher RPM sound?
Stalker
Car: 335I
Default 04-25-2013, 05:30 PM
Wow. That's amazing!! Thanks much. Hey do you mind if I post this over on E90?
spencer123 spencer123 is offline
Car: 1M
Default 04-25-2013, 05:49 PM
Just out of curiosity, you got those numbers with stock exhaust? Stock midpipes? Do you think you could see a few more whp with out those cats and maybe a further single digit increase from exhaust?
Awesome.
BSM 1M, BMS MHD w JB4, Pure Stg 2 DD, FBO, Motion Control Suspension, Stoptechs, big sticky tires, lost control at some point.. M6GC 6MT w JB
Default 04-25-2013, 06:53 PM
Dang...that really demonstrates how quickly us stockers run out of steam. That increasing HP delta from 5k to 6.5k hurts!
Default 04-25-2013, 07:01 PM
Sure rob post away!
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 04-25-2013, 07:16 PM
I run a 80-85 daily. Noticed you used a CM12 nozzle....do you prefer this to the the CM14...would you use a CM12 on a RB powered car also? Just curious.
robc1976's Avatar
Car: 2007 335i
Default 04-25-2013, 07:18 PM
Amazing Terry, honestly is.....this is why I trust and will always use a BMS product!
aramsey80 aramsey80 is offline
Car: 2007 335i 4dr auto
Default 04-25-2013, 09:21 PM
Do you really mean 80% Ethanol / 20% water? Or did you mean 80% Methanol? Just trying to see if your spraying meth or ethanol.
Default 04-25-2013, 09:24 PM
We use ethanol in the meth tank. E98 to be exact. Normally straight, but we had a bit of water in there from installing the kit / testing for leaks. I prefer ethanol because it's not as toxic and is almost the same octane level. It's also easier for us to obtain as we keep 55 gallon drums at the office.
