NLM235I NLM235I is offline
Car: M235i
Default Need help finetuning map 6 - 10-04-2020, 03:09 PM
Car M235i, dcdp, ftp cp, wagner ic, custom exhaust stock air intake, ewg connectors.
Fuel Shell V-power
3rd gear pull in Sport+
Im learning the jb4 and can read the logs a bit. 2 months ago i have changed some settings with the help of Ando, thanks for your help :-) .
Please look at the logs. What can i change more in the settings for a better tune? Maybe you see something that is fine or not. I want to learn. Maybe it is me, but at higher rpms the boost is below target. How to change that, or is that normal. Is Afr good or a bit lean.
Trims, ff, wgdc, fine or is there something to change for better results?
I like to hear from the experts.
Greetz, NLM235i
Car: M235i
Default 10-05-2020, 04:17 PM
PID is 25 in logs. Is lowering it to 20 an aption
Duty bias is 60 logs. Is adding 5 at 5500 and 6000 rpm an option.
Ff wastegate adaption in logs is 100.
FOL is 80
Terry is finetuning these settings usefull? What can i change, and can you explain why?
