rjramirez02's Avatar
rjramirez02 rjramirez02 is offline
Car: 2013 335i E93
Default Log Review switching to MAP 4 - 08-08-2020, 07:34 PM
Need help please. Im not sure why JB4 kept switching to MAP 4 during track day. I have attached several logs in case that helps.
Default 08-08-2020, 08:43 PM
The safety your are throwing is "1" for overboost.
The log files you have uploaded are massive, and frankly hard to read, because they are full of not needed data.
Proper logs to help diagnose issues are generally done in 3rd gear, WOT, traction control fully off.
Car: 2013 335i E93
Default 08-09-2020, 04:48 PM
Thank you for your help. Ill make sure to run proper logs next time. I have to bring it in anyway since a coolant leak has also developed.
Default 08-10-2020, 02:15 PM
Sounds good!
Car: 2013 335i E93
Default 08-18-2020, 06:21 PM
Here are two logs from today. Its not switching to MAP 4 anymore but it looks like boost is dropping off at the higher rpm range.
435gc 435gc is offline
Default 08-20-2020, 06:18 AM
Turn on 6cyl timing.
Set your duty bias to 50 across the board.
Relog.
What fuel are you using?
What plugs are you using and how old are they?
Car: 2013 335i E93
Default 08-20-2020, 06:54 AM
Will do. Im using 93 pump fuel. Plugs are about a month old bosch zr5tpp33.
Default 08-20-2020, 08:23 AM
timing doesn't look great.
we can help the boost curve w. some duty bias tuning, but the stock turbo isn't the most efficient.
Car: 2013 335i E93
Default 08-20-2020, 08:52 AM
What can I do to improve the timing?
Default 08-21-2020, 05:40 AM
Do you have access to e85
How old are your plugs ?
Car: 2013 335i E93
Default 08-21-2020, 07:07 AM
I do have access to e85. Plugs have about 4000 miles on them. I really appreciate your help.
Car: 2013 335i E93
Default 08-21-2020, 05:38 PM
I attached updated logs.
Default 08-22-2020, 05:51 AM
Bump your FOL up to 80
And let’s add 1 gallon of e85 to your current gas tank (unless you are on empty)
Drive around for a few minutes after adding the gallon (let fuel mix)
Then re log, let’s see if that cleans up the timing a bit
Car: 2013 335i E93
Default 08-22-2020, 01:37 PM
Here is the log with FOL at 80 and 1 gallon of E85
Default 08-23-2020, 11:50 AM
Cleaner, still a little noise on 5
Bump your FOL up to 90
how’s the car feel?
Car: 2013 335i E93
Default 08-23-2020, 12:05 PM
Feels much better and smoother. Will change fol to 90 and relog. Thank you!
Car: 2013 335i E93
Default 08-24-2020, 05:39 AM
Could it be an issue with lpfp? I tried to log this morning with fol at 90 (attached) but went into limp mode. The error codes are 2efe, 2f02, 2ee0, 2eed.
Default 08-24-2020, 07:24 AM
Did you just change FOL.
Clear codes & take 1-2 WOT adaption pulls.
Car: 2013 335i E93
Default 08-24-2020, 07:39 AM
I did change the fol and then did the log. Tried to clear the codes but they came right back as soon as I started driving.
Default 08-26-2020, 06:54 AM
Ok, lets drop the FOL back down to 80
Clear codes, and relog
Car: 2013 335i E93
Default 08-26-2020, 07:02 AM
Bad coils were part of the problem. Crazy since I had put new ones on i. December but I changed all of them yesterday. Will relog with fol at 90.
Default 08-26-2020, 12:42 PM
Iíve seen coils bad out of the box, so sadly that doesnít shock me.
Letís see FOL @ 90...
Do 1-2 WOT pulls after the FOL change & then log the next pull
Car: 2013 335i E93
Default 08-26-2020, 04:58 PM
Here it is
Default 08-28-2020, 07:32 AM
Here it is
5k- redline, bump duty bias up by 5
Car: 2013 335i E93
Default 08-28-2020, 08:00 AM
Will do. Ill relog this afternoon.
