(#501)
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 01-17-2018, 06:27 PM
Try these. Not ideal because I ran them in second gear to keep the speed down, but its not making much boost.
Mike Levy
2017 X3 xDrive35i
Default 01-17-2018, 06:44 PM
WGDC is low causing low boost. Duty bias settings missing, FF set too low.
Mike_L's Avatar
Anti-Social
Default 01-17-2018, 06:47 PM
So where should they be set at? I set everything where you said in the first post. Only other change I made was changing from Map 5 to Map 2.
Mike Levy
2017 X3 xDrive35i
Marlinman's Avatar
Car: 335i coupe 2010
Default 01-17-2018, 07:48 PM
cnm135 - thanks! okay I will fine tune that way. I was looking through some of your older posts and noticed the oscillation in yours too so it made me feel a little better.
Also I just took three logs and finally noticed FF adapting to 97.
Pros please have a look, the first is in third and fourth gear (map 6 with 14 PSI across board) settings of (PID - 20, FF - 97, DWG - 80, ASBR - 60, DB settings from page 1) and I thought it looked fantastic. The PWG and FF are matched well and boost seems more on target compared to when I was in map 5.
HOWEVER, I am concerned because when I took a log in fifth gear (same map 6 and settings), it over boosted like a mother....yet the PWG and FF were still in line, the only difference I noticed was a bit of a gap between ECU and DME PSI. Please advise.
I included a third log of fifth gear again in Map 1 for fun.
Thanks again all. This is fun.
Mike_L's Avatar
Anti-Social
Default 01-17-2018, 07:56 PM
Originally Posted by cnm135i
No, you overlooked the DB settings. ISO does not have build-in RPM gain. Set FF=100 and try again. Log in map1.
Thanks. I thought that stuff was only for Map 6. Iíll give it another shot tomorrow.
Mike Levy
2017 X3 xDrive35i
Default 01-17-2018, 09:16 PM
Boost is read pre throttle, so its reading just spiked up because your throttle proportionally closed. Since you don't have the latest interface I can't see what manifold boost was. I guess Apple pushes updates 3-4 weeks after JB4 Mobile publishes them.
Diode is cut on JB4 board right? Assuming so looks like FF needs to be lowered at lower RPM where it's jumping over target.
Also, does it still log normally with FUD = 0? Or do you still need slow speed CANbus?
Mike_L's Avatar
Anti-Social
Default 01-17-2018, 11:07 PM
Since when is manifold boost logged? I cannot find it in my log from today (A208)
I think it’s the boost2 column. If you look at my logs you’ll see it all the way to the right. I have the iOS beta release that came out yesterday (2.3.1, build 7997), so that may be the one where it was added. Or it may be an older one, because you have that column too.
Mike Levy
2017 X3 xDrive35i
Marlinman's Avatar
Default 01-18-2018, 03:49 AM
Boost is read pre throttle, so its reading just spiked up because your throttle proportionally closed. Since you don't have the latest interface I can't see what manifold boost was. I guess Apple pushes updates 3-4 weeks after JB4 Mobile publishes them. Yea I'll look to see if I can update the interface today. I do have the latest firmware though.
I've been logging with slow speed enabled because I was hesitant to disable that function, thinking I'd screw something up
Yep diode for sure is cut, this is the first time I've seen the boost act like that. The logs in the same attachment for 3rd/4th gear this isn't happening so I was confused why all the sudden in fifth it would shoot up like that and since I rarely log in fifth, I was concerned that I saw good things in 3rd and would have missed this otherwise. FF globally was set at 88 and then learned up to 97, I will lower in lower RPM. Will this benefit the other gears as well?
Marlinman's Avatar
Default 01-18-2018, 03:57 AM
also the difference seen between ECU and DME PSI?
Marlinman's Avatar
Default 01-18-2018, 05:21 AM
I took this today. It’s short but it looks more “in line” with other ogs oscillating. No more huge overboosting throughout range. Didn’t change settings.
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 01-18-2018, 10:57 AM
Hi Terry & Guys,
I just installed my ps2 and did some log on map5. I haven't done the diode and iso yet, so should I start my own thread for logs help with fbo+ps2+e40 or I use this thread?
SO, after ps2 installed overboosting & slipping appears of course.
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
Default 01-18-2018, 05:36 PM
Leave it on map0 until you cut the diode update the firmware & settings, etc, and then you can use this thread.
Default 01-18-2018, 05:40 PM
I took this today. Itís short but it looks more ďin lineĒ with other ogs oscillating. No more huge overboosting throughout range. Didnít change settings.
Looks like duty bias below 3500rpm needs to be lowered.
Maybe something like
1500 - 30
2000 - 30
2500 - 30
3000 - 40
3500 - 45
4000 - 50
4500 - 55
5000 - 61
5500 - 68
6000 - 76
6500 - 85
7000 - 85
Marlinman's Avatar
Default 01-18-2018, 06:21 PM
Looks like you raised it here a little in the upper RPMs as well Terry? (compared to your first page recommended starting positions).
Car: 13 f30 335i
Default 01-18-2018, 06:32 PM
Will map2 on regular firmware have any issues if boost stays on target. At leas for now.
Marlinman's Avatar
Default 01-18-2018, 06:46 PM
after my ps2 was installed, I drove home in map 2 and it was fine. Also, the shop used map 2 to test her out before delivering back to me. I also used map 2 with integrated firmware until cutting diode.
Car: 13 f30 335i
Default 01-18-2018, 07:09 PM
So, what the actual improvement from my current old firmware map 2 running fine vs ISO firmware diode cut on the same map2.
Marlinman's Avatar
Default 01-18-2018, 07:28 PM
Terry is more equipped to answer that, but in short, better boost control with your new turbo!
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 01-19-2018, 03:42 AM
i just did one pull with map 2 and i want to know is that looks good and if there is anything that i can do to make it better
AFR used to be 14.6 while in ideal but after updating to the ISO Firmware it became 15.0 and above
here is a log attached
mods:
BMS F30 N55 Performance Intake
fuel used : 98 octane
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default my log not so good - 01-19-2018, 06:09 AM
hi i uploaod T_9 iso
see on my log afr very low
my dme is stock
btw what is boost2?
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
dror135's Avatar
Default 01-19-2018, 07:00 AM
First of all you are running too much boost. Your HPFP is crashing and your timing is not good Try map2 or deduct 2psi from your map6.
It never happened to me
Never dropped my fuel pressure in the front under 11
On the same map and meticulous
I am with new lighters NGK gap 0.020"
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 01-19-2018, 09:25 AM
I flashed the ISO_9 version yesterday. I pulled log in Map5, I still have my FUD set at a value of 128 for Slow CANBUS but now I get much more data including my gear which was not showing with ver ISO_7 T12, great improvement! Anyway, here is a log, let me know what you think and if I need to change any values. I am running with 100% 93 Octane now for the winter. Still on stock turbo. Thanks!
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 ISO_11 - Map 7/e50/Custom tuned exhaust/stock turbo/Resonator Delete/MHD BEF with JB4 e85/Stage 2 LPFP Walbro 450/JB4 BEF
Summer '19 install: Speedtech BW 8374/PI & Tune by Trebila
Default 01-19-2018, 09:30 AM
What happens with normal speed CANbus?
Default 01-19-2018, 09:33 AM
my dme is stock
btw what is boost2?
I think the DME is registering knock and enriching AFR to try to reduce it, and in the process the fuel being injected exceeds what your fuel pump can keep up with. You need to lower boost or increase octane. Or load a BEF and we can reduce ignition advance.
Boost2 is manifold boost but it's not scaled properly in your log. I'll fix it next update.
Default 01-19-2018, 09:35 AM
I haven't tried it yet, I plan to try it later today, I'll report back. So far a success in my eyes.
