(#51)
eddiefromcali eddiefromcali is offline
Car: 2022 Tundra
Default 05-23-2022, 12:43 AM
Weird...worked fine for me right off the bat
roboots21 roboots21 is offline
Car: 2022 Toyota Tundra
Default 05-23-2022, 05:18 AM
Figured it out. After setting Option bit 0 (enable/disable), my JB4 would not be able to switch any maps until a 'reboot' occurred. So I set the option bit, shut off the truck and let it sit until the JB4 app no longer connected to the bluetooth module, and then I restarted the truck. Map selection and switching works as expected with this 'reboot' after setting Option bit 0.
Being a SW/Elec. Engineer, I should have though of the first step in troubleshooting .. when in doubt, reboot! With that, all seems good on my end at this point!
Default 05-24-2022, 07:01 AM
Nice!
CLIFFORDSBIGREDROCKET CLIFFORDSBIGREDROCKET is offline
Car: 22 TUNDRA
Default shuddering under light throttle - 06-10-2022, 06:44 AM
Good morning. Anyone running into shuddering under light throttle gradually ramping to more throttle? usually cruising and just ease on the throttle easy and seems to stumble unless its in higher boost.
Default 06-10-2022, 08:34 AM
See if you can capture it in a log and post it up for us to evaluate, please.
Car: 22 TUNDRA
Default 06-10-2022, 11:02 AM
only thing I can remotely relate shuttering is in the throttle in the graph
Default 06-10-2022, 01:32 PM
The graph and the CSV file loaded are different. Does this happen on map 0?
Car: 22 TUNDRA
Default 06-10-2022, 01:46 PM
IT WAS ON MAP 3 BUT DID DO IT ON MAP 1. I WILL TRY AND GET SMALLER AND MATCHING GRAPH ON THE DIFFERENT MAPS THIS WEEKEND AND SEND
