Ger47 Ger47 is offline
Car: 2008 335i
Default BMW 2008 N54 335i - 126,780 miles - 08-26-2020, 05:37 PM
Dear Members,
Having an issue with a small oil leak (seepage) that comes from the bottom partition of the block to the lower block.
Has anyone experienced this problem and your suggestion to fix it will be appreciated?
Is there a a gasket in between these parts?
Appreciate your comments.
albertc albertc is offline
Car: 2007 335i
Default 08-27-2020, 06:29 AM
post a photo
Bmw335turbo's Avatar
Bmw335turbo Bmw335turbo is offline
Car: 335
Default 08-27-2020, 08:17 AM
Possible oil pan gasket leak it's hard to say without pic's.....
Car: 2008 335i
Default 08-27-2020, 08:31 AM
Oil pan gasket is dry. The small leak is between the split in the low section of the top block to the lower piece that covers the crank bearings.
Thanks for your reply
Car: 2007 335i
Default 08-27-2020, 08:49 AM
blah blah blah. Post a pics or people will keep guessing
MDMA 135i MDMA 135i is offline
Car: BMW 135i
Default 08-27-2020, 09:19 AM
That is engine badplate oil leak. I have that problem.. Very expensive to fix it. There is no gasket there. You need to dissamble engine and put special glue in the hole to glue the block..
Car: 335
Default 08-27-2020, 09:45 AM
