BrandxnVan BrandxnVan is offline
Car: E90 n54
Default Will a bad ecu cause jb4 to go inactive & not work? - 08-18-2020, 09:42 AM
Need answers. Havenít drove my car in over a month and shops arenít helping
Car: 2008 E93
Default 08-18-2020, 11:06 AM
Im confused. a bad ECU can cause your whole car not to work.
Default 08-19-2020, 05:31 PM
If ECU has no software the car won't run, and the JB4 won't boot up either, since they share the same activation signals as the rest of the car.
Car: E90 n54
Default 08-19-2020, 11:44 PM
Well basically I got the alternator and battery replaced because it just randomly died. Before it completely died all the lights on the dash came on including engine power reduced & it wouldn’t go past 2k rpm while driving. After replacing it it’s starts right up but stalls at idle or in gear. It stutters then shuts off & starts right back up. Replaced plugs and coils but still didn’t do anything. Right before it stalls the engine reduced power comes on as well & my jb4 does not show signal anymore which suspects me the dme went bad. Saw a guy have the same problem but basically did his repairs backwards of mine. DME Failure, will JB4/MHD effect it? - N54Tech.com - International Turbo Racing Discussion
Car: E90 n54
Default 08-19-2020, 11:47 PM
Here are the codes I had
2FBE - Fuel pressure after engine stop
30cf- wastegate activation
30do- wastegate activation 2
31oo- boost pressure control deactivation
2B2C- fuel high pressure plausibility, cold start
Misfire codes ( 29cf, 29ce, 29cc
2abd- boost pressure sensor overrun
2e8b-intelligent battery sensor signal
Edit/Delete Message
