elchicodeleste elchicodeleste is offline
Car: BMW 135i e82
Default JB4 help with wiring - 08-17-2020, 12:47 AM
Hello fellas. I have some problems with the afr (only when boosting over 8psi). Seems the afr1 is unstable while afr2 works well. JB4 switches to map 4 (AFR lean) I have DP fix installed. Could this be producing the problem?
I attached a photo to make sure this is the DP fix (as it does not have potentiometer).
Car: 2008 E93
Default 08-17-2020, 12:53 AM
Yes
Car: BMW 135i e82
Default 08-17-2020, 03:24 AM
Yes
Yes to what?
Could this be the problem? Is that thing the dp fix? Thanks in advance!
Car: 2008 E93
Default 08-17-2020, 09:59 AM
Originally Posted by elchicodeleste
Yes to what?
Yes
codesx's Avatar
codesx codesx is offline
Default 08-19-2020, 11:26 AM
Yes
You must be on the BMS payroll now, BEAST?
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 E93
Default 08-19-2020, 01:59 PM
Naw...im still Pófolks
Default 08-19-2020, 05:29 PM
Looks like a wired in SLD? Either way remove it and toss it.
