ludo ludo is offline
Car: E93 335i
Default Boost drop in high RPM - 08-12-2020, 08:15 AM
Hi guys !!
Iím experiencing boost drop when my target is at 27 psi or higher
Especially at 6000rpm
Any idea ?
Log attached
Setup :
FBO+ meth port injected+ MMP1K+ turbo smart diverted valve
Car: 2010 135i
Default 08-12-2020, 03:56 PM
tq tables and airflow model, look into them
2010 135i auto,
Car: E93 335i
Default 08-13-2020, 05:56 AM
Thanks for your help, will try this
As you can see, the duty is moving, trying to hold the pressure but it still lose pressure
Car: E93 335i
Default 08-13-2020, 07:09 AM
[QUOTE=iminhell1;672396]tq tables and airflow model, look into them[/QUOTE
Still same issue
Default 08-13-2020, 08:12 AM
FF is basically maxed & wgdc starts to creep up & nearly max as boost starts to fall.
Disable wastegate adaptation in FUD
Manually lower your FF from 149 to 70
relog
