Default Radium Fuel Hanger Surge Tank - 04-21-2020, 09:46 AM
Ordered in around 10 of these last year with plans to develop a package with fuel pumps and lines, and just never got to it. Looking to clear out our inventory so put them on sale for $475 each. While supplies last!
https://www.burgertuning.com/product...s-not-included
Default 04-22-2020, 10:20 AM
Steal!!!
stickz23 stickz23 is offline
Car: e92 335i
Default 08-24-2020, 03:49 PM
Interested in a kit but looking to understand install and activating triggers a bit more. Havenít found a detailed thread on this kit but if you can point me in the right direction Iíd like to research a bit more.
Currently have PR stage3 pump with hobb switch activating the second lpfp pump. Iím using a BMS controller for the port injection and the LPFP/HPFP PSI is in the high 70s low 80s for LPFP and 9s for the HPFP at WOT. I run 100% E85.
Upon hard cornering and only during hard cornering, (360 degree hwy ramps)I get the 29DC cylinder injection switch off code which I believe is due to fuel starvation.
If I get this kit, will my lpfp be an overkill since itíll turn into a lifter pump?
Will I need to remove my existing stage 3 lpfp & hobb switch?
Will the radium pump be on 100% of the time or is there an added controller needed?
Thanks for the support.
