(#126)
tunanocrust tunanocrust is offline
Car: 07 335i MT
Default 04-03-2019, 11:21 AM
Building one of the Mfactory diffs. Large housing with a 3.08 Ring gear (07 335i coupe, Manual, Vehicle Build date 09/06).
Was hoping someone could provide the following tolerances;
- Backlash
- Bearing Preload
I've done some searching and found a couple different tolerance suggestions for Backlash but not much at all on Bearing Preload.
MFactory MFactory is offline
Car: BMW E92 M3
Default 04-03-2019, 11:32 AM
If you give our shop a call, they should be able to assist: 909-592-5933
theobjectivist theobjectivist is offline
Car: 2008 535i
Default 04-06-2019, 08:10 AM
can you confirm options for a 535i 6 speed?
I need a built diff sent to me first and then I send my core back. Is it true that these are custom units only, and with elevated pricing?
Car: BMW E92 M3
Default 04-06-2019, 12:45 PM
You would need to give our shop a call regarding cores/built diffs: 909-592-5933
Default 10-27-2019, 05:33 PM
Sounds like the transmission. What are the codes thrown?
Car: BMW E92 M3
Default 10-28-2019, 08:15 AM
Car: BMW E92 M3
Default 01-29-2020, 01:00 AM
All PM's replied
crazyyardie's Avatar
crazyyardie crazyyardie is offline
Car: 2007 335i
Default 01-29-2020, 02:52 AM
I have a 2008 135i mt with welded. I'm interested in lsd.
Is there a link for this kit ?
Helical LSD E9X 335i (Welded MT/DCT/335d) - $999.95 + $799.95 for Rebuild Kit (Includes BRAND NEW 2.56/2.81/3.08 MFactory Bolted Ring & Pinion, Ring Gear Bolts, Shim Kit & Solid Pinion Sleeve. No Machining Required!)
Car: BMW E92 M3
Default 01-29-2020, 03:35 AM
If you give our shop a call, they can assist you: 909-592-5933
