(#151)
tofu tofu is offline
Car: 335i e92
Default 08-10-2016, 11:13 PM
Originally Posted by BrownPower
great work guys. one questions with the PUMP BEF and map 3.
What is the base boost on map 3 before the meth adders kick in?
I have the latest jb4 firmware and BEF.
i guess you could set it to 0 and log it
BrownPower's Avatar
BrownPower BrownPower is offline
Car: 2008 535i
Default 08-11-2016, 06:47 AM
I thought about that but was not sure if have any values and or even the FSB connected would alter it in some way?
Located in Toronto
Cars:
2006 Saab 9-3 Aero 335whp+390wtq
2008 BMW 535i; JB4, MHD PUMP BEF, DCI, VRSF KOTLESS, ER CP TIAL BOV, RB PCV
StormShadow335 StormShadow335 is offline
Car: 355i
Default 09-15-2016, 06:22 PM
I hope this thread isn't dead. I was looking forward to info on the updates to the JB4 BEF and dyno results.
2008 335i 6MT, Doc Race Precision 6062 GEN2 kit, JB4 ST BEF, BMS Meth & dual OCC kit, Helix hpfp, Boost Concepts Stg 2 lpfp, VRSF 3.5" exhaust, & FMIC, ER CP, HKS BOV, 550i clutch.
jgj925 jgj925 is offline
Car: 09 335i xDrive
Default 04-17-2017, 02:06 PM
bump for updates...unless they are being posted elsewhere
Default 04-17-2017, 02:09 PM
This is an old thread. Updates are posted to the BEF thread, JB4 thread, etc.
DomSquad DomSquad is offline
Car: BMW 335i N55
Default 08-16-2017, 07:03 AM
If using 4/4 (Flash only) on a N55 Harness B JB4, what is the equivalent of the white connector? Is it the boost solenoid (Blue) that needs to be reconnected to to stock?
What Id like to do is try MHD out without having to remove the JB4. But I see my self in the long run using JB4 with a BEF.
Default 08-16-2017, 09:33 AM
For N55 you put blue solenoid patch only to stock.
Car: BMW 335i N55
Default 08-17-2017, 06:08 AM
Thanks Terry!
Car: BMW 335i N55
Default 08-18-2017, 05:09 PM
Just flashed MHD stage 2+ 93 Oct, went to 4/4 (Flash Only) and then set to 0/4 (Map 4). I did this instead of Map 0 because I left the boost solenoid connected to JB4. With this setup I am not creating boost although my boost target is 18psi.. Any ideas as to what could be the cause of generating zero boost?
**EDIT** I did some tinkering and found that if i switch back to 4/3 (Default) and run Map 4 (OEM tune, in this case MHD flash), I am now ABLE to generate boost.
Terry@BMS
Is there anything I should be aware of when running in this setup?
Also, why was 4/4 not working? I assume a huge misunderstanding on my part but feel it could be a bug.
Default 08-19-2017, 03:33 PM
If you have an N55 this is the wrong thread for you. If running 4/4 on N55 boost solenoid must be reverted to stock.
Con535 Con535 is offline
Car: 2010 bmw 535
Default 11-25-2017, 04:56 PM
Will Bms meth kit still flow with white sub connector removed and 4/4 mode? Also is map 4 or 0 supposed to be used in flash only mode?
Default 11-25-2017, 05:01 PM
Meth will still turn on as long as map is > 0. On 4/4 all maps act the same other than 0.
