gixercho's Avatar
gixercho gixercho is offline
Default 11-22-2015, 09:22 AM
Little update
gixercho's Avatar
Default 11-23-2015, 08:57 AM
more pics
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 11-23-2015, 09:06 AM
Weld porn. this is NICE!
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
MadMan77's Avatar
MadMan77 MadMan77 is offline
← Ex-Con
Car: JB 135i
Default 11-24-2015, 01:42 AM
No kidding!
Patrick4588's Avatar
Patrick4588 Patrick4588 is offline
Car: 2010 335i and 2006 M3
Default 11-24-2015, 06:32 AM
Its beautiful
justa335i's Avatar
justa335i justa335i is offline
Car: 07 E92 335i
Default 11-24-2015, 07:11 AM
Looks great! Cant wait to see what she puts down.
2007 E92 335i 6MT
New Jersey
N54-Tuning 3'' Downp!pes, Vrsf 5'' Intercooler, Vrsf Charge Pipe, Tial-Q BOV, Vrsf Lower Charge Pipe, Act HDSD Clutch, JB4 G5 ISO, BMS Intakes, Custom Axle Back w/ 3" Tips
gixercho's Avatar
Default 11-24-2015, 08:15 AM
I think it will have big potential, but the problem is that we do not have access to E85 here, only in small quantities in drums and if e get PI and stage3 LPFP i'll have to use them only for glory runs.
gixercho's Avatar
Default 11-25-2015, 07:43 AM
pre mount
gixercho's Avatar
Default 11-25-2015, 12:16 PM
Manifold is ready
matthewo matthewo is offline
Default 11-25-2015, 12:47 PM
I think I this is suitable
gixercho's Avatar
Default 11-25-2015, 01:04 PM
two more
Rain's Avatar
Rain Rain is offline
Car: E92 335i '07 Manual
Default 11-25-2015, 01:09 PM
Nice Looking forward for the result as well!
E92 335i, 2007, manual
Mfactory helical LSD, ST XA Coilovers, EBC Grooved Discs + Yellowstuff pads + Goodridge lines, 313 Performance wheels, OEM turbos
JB4 + Rev3, MHD JB4 BEF, BMS Clutch stop, Custom ©atless dоwnpipes, VRSF 7" FMIC, VRSF CP + Tial BOV, VRSF OEM Silicone inlets + OCC, Yokohama AD08R, BMS CDV
396 whp, 639 wnm (471 ft lb) 93-95 Pump gas, no meth, no ethanol
gixercho's Avatar
Default 12-07-2015, 03:57 PM
oil and coolant lines are ready and car started for first time
rhm135's Avatar
rhm135 rhm135 is offline
Tech
Car: 335is
Default 12-07-2015, 04:12 PM
Subscribed!
2012 335is DCT - JB4 - Fuel-it! - MHD - SSP - DocRace
Car: 2007 e90 335i
Default 12-07-2015, 07:44 PM
This looks so sick!!!!
2007 e90 335i
The Leopard's Avatar
Car: E92
Default 12-07-2015, 07:57 PM
Looking good!
TS N54
BeGooD69 BeGooD69 is offline
Car: 2007 335i
Default 12-08-2015, 10:29 AM
looks really good... good job...
gixercho's Avatar
Default 12-08-2015, 02:08 PM
Latest pictures
gixercho's Avatar
Default 12-23-2015, 12:25 PM
Yesterday i had a dyno on may way and i test the car on it. Because i had no arrangements they do not gave me enough time to dial in the duty bias to hit targets on the dyno and because of that the boost is 18.5psi in the revs where the car should made most of the power. They lost my map2 run with 17psi where the boost was on target and the car produce 478whp and around 590wNM. On the road the car hit 23-24 psi with no problems in any revs, but the fuel is on the edge (94octane pump). The flash is base JB4 MHD ST pump flash and the JB4 is not dialed in, i had no time to this moment for a custom tune and those are praliminary results.
gixercho's Avatar
Default 12-23-2015, 12:31 PM
Hmm now i just sow the the ceorection factor is SAE and the numbers are lower than if it was STD. I'll ask the guys from the dyno to send me the graphs STD corrected.
BostonBeemah's Avatar
Car: AW 135i
Default 12-23-2015, 02:47 PM
Nice initial results! Spool is good imo with relatively no tuning yet. Can't wait to see what she makes cranked up once you get the fueling addressed.
RIP 2008 AW/BL 135i
Car: E92
Default 12-23-2015, 05:20 PM
Looks good buddy! Your spool and power is inline with what you'd expect at that boost level.
TS N54
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 12-24-2015, 06:00 AM
subscribed
Taron's Avatar
Car: 2008 BMW 335XI
Default 12-24-2015, 06:14 AM
interested to know how much is your pwm?
ThaCuda's Avatar
Car: 2007 335i
Default 01-02-2016, 06:13 PM
Updates? Looks great
