(#51)
lamboworld lamboworld is offline
Default 08-25-2015, 02:07 PM
Originally Posted by PR3CI5N335i
So far so good on the trans. I run 25psi on the streets with no issues. NFZ AZ is coming up in 6 weeks so we'll see after that.
Yes my car is still on E50 + 100% Meth. I had no idea this setup could make this type of power! I think it helps that my lpfp and hpfp are new.
Your numbers look great. Even without meth you would probably still be over 600whp on E50.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 08-31-2015, 06:26 AM
Wooow
I never thought i would upgrade my turbo but seeing those numbers make me so keen, I'm waiting for S2 N54 pure
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
ceke1985 ceke1985 is offline
Car: BMW E91 335I N54 2007
Default 09-30-2015, 03:05 AM
Me and a friend ordered the Pure stage 2 kit for our N54. Looking forward!
Any more news already?
Greetz
Cédric ( Belgium)
Welterweight Welterweight is offline
Car: E92
Default 09-30-2015, 06:12 AM
Are these ready to go? The numbers are so impressive!
Pure Turbos's Avatar
Default 09-30-2015, 07:36 AM
They are. We are finishing building a batch now. Announcement thread with pics coming soon. Feel free to contact charles@pureturbos.com to inquire about the turbos.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 09-30-2015, 07:53 AM
Great result!
I am about to head down the same path myself lol Not sure about running 28psi though
Btw, are your hpfp values ok at these power levels esp on the road? I noticed you are only running E50 with Meth.
Cheers
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018” gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020”, stock everything else, 374.9 rwkw Mainline Dyno Aus
Default 09-30-2015, 08:11 AM
Originally Posted by DSCOFF
Great result!
Cheers
This car only has a stg1 inline fuel pump. With e60, the hpfp was dropping off at high boost. It would probably do better with a Fuel-It Stg2. He switched to e50 and hpfp stayed up. Thanks
Marlinman's Avatar
Car: 335i coupe 2010
Default 09-30-2015, 11:00 AM
AMAZING
THANK YOU FOR ALL THE HARD WORK AND HONEST INFO THUS FAR!!!!
Need to get to FBO first but this is so exciting.
Peter @ Pure's Avatar
Car: F20 M135i
Default 09-30-2015, 11:15 AM
Pure always delivers!
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 09-30-2015, 12:01 PM
OP just updated the first post with the latest dyno results. Thanks
Default 09-30-2015, 10:20 PM
Greetz
Cédric
Quicktime's Avatar
Quicktime Quicktime is offline
Car: 2008 335i
Default 10-01-2015, 06:55 AM
700WHP trough a auto?!?! Insanely nice. Congrats!!
Spool looks a little slow! LOL Sorry I couldn't resist.
Weehe Weehe is offline
Default 10-01-2015, 07:42 AM
The red line is a Motiv 750 single, blue is the Pure stg2...
Default 10-01-2015, 11:57 AM
RSTECH RSTECH is offline
Car: e90 335i xdrive
Default 10-01-2015, 12:57 PM
683, nice!
He still running the exact fuel set up as last dyno results just some more tuning?
2010 e90 m-sport a/w xdrive, jb4, d_wnpipes, muffler delete, 40/60 e85/93 RIP
2010 e90 a/w xdrive mhd v5 e40 map, ar d_wnPipes, vrsf charge pipe, tial blow off valve.
95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg 4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, under 2000 lbs with driver.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 10-01-2015, 01:19 PM
Originally Posted by RSTECH
683, nice!
I'm still running the same fuel setup but will be switching over to PI very soon.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 10-01-2015, 05:22 PM
Will there be a stage 1 as well?
Need4Speed
Default 10-01-2015, 08:06 PM
Not that I know of. You would want more power after a few months anyways so may as well go stage 2
Car: E92
Default 10-02-2015, 06:56 AM
So let me get this right. You hit 700 whp with only LPFP and FBO?
Newguy123's Avatar
Car: 12' 135i
Default 10-02-2015, 07:30 AM
And PUREs n54 stage 2 hybrids
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Indo Rider's Avatar
Indo Rider Indo Rider is offline
Car: 135
Default 10-02-2015, 07:34 AM
Are you guys actually looking at the posted dyno? Sorry in advance if you are color blind. Great results, but try not to confuse people here if at all possible, that only brings drama.
2009 135i 6MT Jet Black, FBO+
Need4Speed
Default 10-02-2015, 10:13 AM
AT, FBO (stage 1 inline LPFP), E50 + 100% Meth, Pure stage 2 and TFT inlets.
These comparison graphs were made by Terry. Each graph is labeled so there's really nothing confusing about them.
Default 10-02-2015, 10:52 AM
I will run the same specs. RB inlets, BMS meth injection, ethanol, pure stage 2 etc...
My wastegates are day by day making more strange noises. So I will be glad when the set arrives in Europe and I will hit 600 hp and more instead of 400hp and boostcuts
Need4Speed
Default 10-02-2015, 11:41 AM
Are you AT or MT? I'm not sure if you're Peters friend from Europe, if you are, I'm looking forward to some race videos between you two. He'll have less power than you but I know his car is very light so should make for some great races.
Car: 2007 e90 335i
Default 10-02-2015, 02:31 PM
So how much do these things cost?
2007 e90 335i
