(#51)
Default 03-25-2015, 01:02 PM
It can enable the meth pump but there is no safety. 2STEP should work. Try it.
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 03-25-2015, 01:05 PM
Would it still use the settings under the meth tab like boost additive?
houtan houtan is offline
Default 03-25-2015, 01:17 PM
To that end I'd rather spend the engineering time developing new and innovative features to appeal to would be flash only customers as I'm confident the demand will be there.
Are you considering bringing these innovative features to the n55 crowd as well? We are already missing 6 cylinder logging. Happy for the n54 crowd, but Just trying to get a feel of what is down the road for the n55s.
Default 03-25-2015, 01:31 PM
The N55 is a few years behind the N54. I don't know when things will improve for the N55, but we own several for development purposes and work on them as time permits.
No those would not be relevant anymore. Just the min boost before meth can activate setting.
marconi118 marconi118 is offline
Default 03-26-2015, 11:49 AM
and developing a beta firmware for us enthusiasts? without any support
would it be costly?
cantool already reads boost from CAN
Default 03-26-2015, 11:50 AM
would it be costly?
How about I give it a firm maybe?
Car: vw passat
Default 03-26-2015, 05:37 PM
so if i am trying out the mhd e40 tune would i want option A or B? and the two hex files in the first post, is the first option A and the second option B.
with option A does the flash control wgdc?
Mauricio @ MMP's Avatar
Mauricio @ MMP Mauricio @ MMP is offline
Car: 335i Cp TiAg JB3 DCI
Default 03-27-2015, 08:47 AM
Terry, can you please adjust the firmware for 3.5bar sensor so that it works when the flash has been scaled for the 3.5 bar voltages? Issue is when running option B map 0, car wont run.
Stock Turbo 500whp 540wtq with MMP inlets
http://mmp-e.com
  • inlets (high flow and one piece silicone)
  • high flow outlets
  • turbo development
Default 03-27-2015, 08:52 AM
I don't foresee doing that as there are several technical issues with it. Scale your flash map for the OEM sensor and then have the JB4 do the MAP sensor scaling conversion.
Default 03-27-2015, 09:03 AM
Probably option B to test a stand alone flash map.
Car: vw passat
Default 03-27-2015, 12:03 PM
but does jb4 control wgdc with option A?
Car: 09 E92 SG
Default 03-27-2015, 12:05 PM
From what I read, yes.
Default 03-27-2015, 05:37 PM
Yes, so no tuning is required.
Just as an aside I've seen some pretty scary logs under option B from those who were previously running custom flash tuning. You just can't safely tune an N54 without an active PID system targeting an actual boost set point. That said being able to monitor true boost values is an absolute requirement for anyone running flash only. When the log says 21psi it could be 21psi or it could be 25psi or it could be 36psi. You'd never know. I'd strongly suggest anyone running aggressive boost levels on a flash tune to invest in a real boost gauge if they don't want to use a JB4 for logging.
kenjermen's Avatar
kenjermen kenjermen is offline
Car: 2009 BMW 335i
Default 03-28-2015, 10:25 PM
if i do a wedge flash with option b will i be able to log with the jb4? so will the hijacking boost gauge be off once in option b?
2009 BMW 335I with: MHD/Haltech,
precision 6870 turbo, jp Workz header,
Wagner EVO II intercooler,HKS exhaust with cutouts, stage 3 lpfp, wavtech lsd, eospeed intake manifold with fuel return and 60lb injectors
Default 03-28-2015, 10:44 PM
Yes you'll log and use gauges with the JB4 as you normally would.
Spxxx's Avatar
Spxxx Spxxx is offline
Default 04-01-2015, 08:25 AM
So with option A, the jb4 I still controlling the WGs it's just targeting what the flash tells it to? The DME isn't controlling wgdc
Default 04-01-2015, 09:45 AM
Correct.
Robert's Avatar
Robert Robert is offline
Car: bmw
Default 04-01-2015, 10:12 AM
Can we run BMS meth using option A over MHD flash ???
If yes. Which map would be appropriate ???
2008 e92/MHD Wedge E85/Alpina TCU /RB Inlets/MMP Outlets/Vrsf DP/Helix FMIC/Forge DV/BMS CP/DCI/Fuel It st2/TBI/TC Kline/Swift SA coils/MF lsd/Hotchkis sway bars/M3 front and rear links/ Diff LDK/AKG Race subf/diff bushings/Megan toe links /TSW18 forged Nurburring/Mich PSS 245/265 /BMW(Brembo)M perf 370mm BBK
Default 04-01-2015, 11:08 AM
The MHD maps intended as stand alone maps are not going to be optimal for meth. If you want to use meth you should use an appropriate back end flash map. We're testing MHD specific higher load maps currently so that would make the most sense.
Default 04-03-2015, 09:29 AM
We've had a few customers test the OptionB fully passive mode now. And for the most part its been working as intended. Customers have an easy way to view boost in dash, capture and quickly view logs, and most importantly can datalog boost values higher than 21psi. It's been a real eye opener.
Some of you custom flash only cars, maybe without knowing it, are disabling your boost control system and duty cycle tuning above the TMAP sensor range. It's really risky stuff.
You'll know if you're doing this because your flash log will show boost stuck at say 21psi. Meanwhile actual boost could be anywhere from 21psi to 40psi. With the DME blind to boost there is absolutely no control. You or your tuner may go along thinking boost can't be that much higher than 21psi but I've seen in more than one case boost going off the charts. Here is a recent stock turbo "dyno record" log that was recorded via the JB4 in passive mode. Boost went up to 36psi and maxed out the N20 TMAP sensor!
Anyway the moral of this story is DO NOT DUTY CYCLE TUNE. Even if you do manage to set boost perfectly using an external gauge as soon as EGT creeps up, weather changes, etc, boost can still rocket out of control. A PID system is required to provide dynamic and safe control. Ideally one with an active throttle over boost safety system in place.
For proper boost control:
1) Always run a boost target that is 1-2psi BELOW your TMAP sensor range to allow the PID boost control system to compensate for over boost situations and to remain fully active. So flash only guys that means never let your tuning target more than 20psi for an OEM sensor or 21psi for an N20 TMAP sensor scaled within the flash.
2) If boost in flash only logs is going to a point and clamping there, and not throwing a sensor out of range fault, something is wrong with your tuning.
3) If your throttle does not start to close, even if boost is exceeding the boost target, something is wrong with your tuning.
4) If you see someone posting logs where boost clamps at say 21psi, claiming it's not running much more boost than that, point out to them boost could be maxing out to 35-40psi and they would never even know it.
Nniftyfour's Avatar
Default 04-03-2015, 09:49 AM
^ Yep, honestly it boggles my mind how a tuner could think a tune like that is kosher for a eveyday Joe who just wants a really fast car. There will be no shortage of stock turbo cores soon.
Default 04-03-2015, 09:50 AM
Forget turbo cores. Those are cheap. That is how you break pistons.
Nniftyfour's Avatar
Default 04-03-2015, 10:02 AM
Yeah good point. 36psi of boost and 12 degrees of timing at 3500rpm. But if they start breaking motors that isn't why... the person inevitably had hardware issues that was outside of tuners control, don't you know.
Can't help everybody.
DV135i's Avatar
DV135i DV135i is offline
Default 04-03-2015, 10:03 AM
That log is crazy!! Over boosting by 15lbs seems like the perfect way to destroy a motor
So this is what the current mhd maps are doing right now? I really wanted to test out the e40 map, but it looks like that's a bad idea right now. Is this happening only when using option b? Option A would still be controlling things so it wouldn't allow the boost to spike like this right?
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
