(#51)
miksebik miksebik is offline
Default 07-27-2015, 03:28 AM
E85 BMS flash, E60, map7: I ran 12.5s but had to shift at 6000rpm (boost at 18PSI) so as not to get limp - my throttle body puts me into limp, when passing 6500 rpm
I had 12.9 when I got limp after shifting to fourth. So the last 100-150m I went on neutral :-D
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
omarmarji's Avatar
Car: n54 335
Default 07-27-2015, 11:54 AM
BB pump flash with e30 mix fbo i ran 12.4.. with a 2.0 60'... i got better tires now
rickybobby also got a 2.0 60' for some odd reason and i forgot what he was trapin
335xiboost's Avatar
335xiboost 335xiboost is offline
Car: 2008 335xi jb+ VSRF ******* DP DCI cabin filter delete
Default 07-27-2015, 05:51 PM
Makes me want more power from my XI nice work!
2014 M5 1 of 577 6spd awaiting MORE BOOST
07 Cayman 5sp
08 Cayman S 6spd
02 996 TT 6spd more boossttt
04 Gallardo gated 6spd
sk55 sk55 is offline
Car: 335xi coupe
Default 07-28-2015, 02:07 PM
I just got new hexon r550 with inlets. The spool
Sounds intoxicating.
Few points on the install.
I believe the waste gate actuators on hexon are not
New. So I ordered new ones from bmw. Cheap insurance
For waste gate rattle.
Ordered Ecs turbo install kit for new gaskets.
The oil lines and coolant lines are pretty much metal
Mine looked good so I kept them save you 400 bucks.
Used fresh motor oil to break in the turbo.
I broke them in for about 500 miles with boost under 10.
Using Bms flash running e60 e85. Run 15 psi right now
The torque is amazing.
Blew135 Blew135 is offline
Default 07-28-2015, 04:37 PM
Check ur pm
Default 07-28-2015, 04:55 PM
Mines come in this Friday. Any pointers on install. Already got my new oil, new coolant, ecs install kit and inlets are on the way from vargas
sk54 sk54 is offline
Default 07-28-2015, 07:22 PM
mojo,
i would say get new wastegate actuators from bmw. cost u $60 for the pair.
Also there a calibration guide for the wastegate... get that from hexon... you have to do this even if you don't get new WGA...
just drive easy for 500 miles.. u can go wot but keep boost under 10.
take a pic of your engine bay after vargus intake.
Default 07-28-2015, 09:52 PM
Originally Posted by sk54
mojo,
Wayne ensured me they are brand new wga and ready to install. I will re check with him regarding recalibration
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 08-06-2015, 07:56 PM
Any updates from guys that installed them?
omarmarji's Avatar
Car: n54 335
Default 08-06-2015, 11:03 PM
from rickyboby?
