Go Back   N54Tech.com - International Turbo Racing Discussion > Model-Specific Engine Tuning & Modification Discussion > N54
Reload this Page *NEW* hybrid turbo stage 3 kit – MM Performance Parts
View Poll Results: Would you buy these turbos?
Yes 127 80.89%
No 30 19.11%
Voters: 157. You may not vote on this poll
Mauricio @ MMP's Avatar
Mauricio @ MMP Mauricio @ MMP is offline
Car: 335i Cp TiAg JB3 DCI
Cool *NEW* hybrid turbo stage 3 kit – MM Performance Parts - 02-22-2015, 09:49 PM
Hello everyone. I’ve been working on a project for the N54 community for a couple months but had not announced it since I wanted to be sure the concept was feasible. I have done enough now to know the concept is good so ready to share my R&D progress with the community.
Description
It is a TD04L-20T with true 20T native compressor housing. The 20T mistubishi profile compressor wheel is a forged billet wheel with extended tip technology from BorgWarner. The Turbo consist of a TD04 bearing housing modified to connect to stock oil lines, coolant lines and stock turbine housing. The turbine housing has been modified to accept the TD04L turbine and flange up to the TD04 bearing housing. The kit will include upgraded inlet pipe system and also charge pipe system optimized for the high flowing native 20T compressor housing which is over twice the size/flow of stock compressor housing. This will make sure the turbos are flowing to their maximum potential along with the upgraded plumbing for the turbo included. This turbo can push up to 35psi of boost and not sure what the actual WHP will be on the N54, but with proper fueling and meth cooling should be in the 750whp range theoretically at those boost levels near redline according to estimated compressor map and turbo HP calcs, only testing will prove if this is possible and I intend to test the prototypes to these levels.
Schedule
Current schedule is to finish development of the prototype set by the end of April/ear;y May and install on my car and test and tune/dyno and then get them on 2-3 beta testers cars by April or May. If all goes well, start selling the kits to you all in the summer. I have completed my test fit on an N54 motor and finalized the designs for the wastegate actuator mounting and modifications and charge pipe (turbo to IC) design as well as making sure everything is going to fit on the engine. Everything went perfect on the fitup of the turbo to the engine so that’s when I decided it was time to start sharing R&D progress with the N54 community.
Pricing
Don’t have my final production pricing yet price point will be $3050 for both turbos, $450 for the basic inlet kit and $500 for the charge ***** from turbo to intercooler. If you already own my inlet pipe system, obviously no need to buy that. Only thing needed to adapt my inlet pipe system to the new turbos is two new elbows and everything else works
Testing
On my prototype system I plan to do dyno test and tune and push them to the maximum as I will have all the supporting fuel mods needed. I will be doing full logging of course. In addition, I will be doing custom turbo logging never before seen on the N54. Not only will I be logging EGT and backpressure (done before) to check health of the turbine but also I will log pressure and temperature at the turbo inlet and also at the turbo outlet which will tell me exactly what pressure ratios the turbo is working at and also at what efficiency. This compressor logging has never been done to my knowledge on the N54 but is the only real way to understand the compressor health during turbo operation.
Quality
The turbos are purchased from a large turbo supplier. I bought the CHRA from them to my specs which were basically TD04 bearing housing with 04L turbine and 20T billet 6x6 compressor wheel with extended tip technology from BorgWarner (for more boost). I also ordered the CHRA with upgraded thrust bearing, actually the highest upgrade possible, steel thrust bearing mitsubishi uses in the rally turbo cars where turbos REALLY get beat on and need bullet proof bearings. The compressor housing is the native 20T housing (over 2x more flow area) for TD04 and the entire CHRA is assembled and balanced by the manufacturer on a VSR machine they have in house and individual report provided for confirmation. I get the turbine housing machined at a CNC machine shop locally that deals with very high tolerance precision drilling tool parts and I assemble the CHRA to the turbine housing and wastegates "in my garage" and bench test wastegates on the turbos to ensure proper settings. Important to note the machine shop I use because I have been to several turbo shops locally and the machining they do is a joke compared to high end CNC shops in Houston like I am using.
Pics
Now some pics to show you some progress
Default 02-22-2015, 09:51 PM
reserved
Default 02-22-2015, 09:52 PM
reserved #2
natedog7700's Avatar
Car: 2007 bmw 335i e90 auto
Default 02-22-2015, 10:12 PM
Wow looking good!
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 02-22-2015, 10:27 PM
Very interesting. Eagerly waiting to see how these perform.
335is DCT
A_Lightyear A_Lightyear is offline
Default 02-22-2015, 10:59 PM
Subscribed.
Its awesome to finally see more options for upgraded snails, rather then everyone switching to single.
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 02-22-2015, 11:23 PM
Wow... Taking the bull by the horns... Nice...
spain4065 spain4065 is offline
Car: e82
Default 02-22-2015, 11:26 PM
NICE! Looking fwd to seeing what wedge/BQ can do with those monsters!
Formula1RR Formula1RR is offline
Car: 2007 335i coupe
Default 02-23-2015, 02:28 AM
Need a beta tester? :p
ba114's Avatar
ba114 ba114 is offline
Car: 135i 6MT
Default 02-23-2015, 03:20 AM
as with all post about upgrades, posting interest for RHD
windymissile windymissile is offline
Default 02-23-2015, 04:10 AM
Rear turbo looks like the pipework may need some attention but I can't see why it can't be made to work.
WM
ross22 ross22 is offline
Car: 2007 BMW 335i
Default 02-23-2015, 06:18 AM
Necessity is the mother of invention. Good luck in brining more HP options for this great platform.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 02-23-2015, 07:36 AM
I'm going ST w/ an EFR, but still want to sub here to see where this goes. The upgraded WG is a very good idea, I'd take Rob's advice there.
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 02-23-2015, 09:20 AM
Sub'd, wish my car was not automatic
e92
Default 02-23-2015, 09:40 AM
My car is automatic and that aint stopping me
Also a buddy of mine here in Houston is doing a 900+whp build with an automatic (level 10 upgrade) with a PT 6766 single setup so if he can get it done, no problem for power at these hybrid turbo power levels.
Stock Turbo 500whp 540wtq with MMP inlets
http://mmp-e.com
  • inlets (high flow and one piece silicone)
  • high flow outlets
  • turbo development
Default 02-23-2015, 09:41 AM
If we can get the inlet pipe kit to work, should not be a problem. working with a guy in the UK to try and get this sorted.
http://mmp-e.com
  • high flow outlets
  • turbo development
black535xi's Avatar
black535xi black535xi is offline
Car: 535xi
Default 02-23-2015, 10:50 AM
As always... will this fit the e60 xi?
2010 535xi
ALL black, murdered out FBO jb4+flash
Fuel It! stage 2 LPFP on the way
12.400@112.16/1.731 60'
4205lbs
///Mposter's Avatar
///Mposter ///Mposter is offline
Default 02-23-2015, 11:35 AM
I was going to PM you about this since I was following you on some of the initial questions you had in the past. Some of the pictures were very similar to some I took of mine as well. I wasn't sure if you were just building a one-off for your own. I'm glad to see that you are contributing to the community. I wish you the best and I hope to see some people jump on it and get them installed.
I am also glad to see that you were able to clear the rear turbo compressor housing. I had not gotten that far, and it already looks as if it is successful. I will be checking in time to time as this gets updated.
Cheers
Default 02-23-2015, 11:54 AM
Thanks man. I think there is one other person doing custom hybrids also (threethirtyfive). Initially I was just doing the project for myself but I enjoy it so much and saw that I could offer a good price point, I figured I would offer it up to anyone who wants it to help out the community
http://mmp-e.com
  • high flow outlets
  • turbo development
Default 02-23-2015, 11:56 AM
Tough to say man, in time will work on this option with one of you guys in the UK. With all the XI stuff right around the turbos, going to be tough to make it all fit but I need to see one in person.
http://mmp-e.com
  • high flow outlets
  • turbo development
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 02-24-2015, 11:21 AM
Looks good so far, lots of stuff you are not addressing, but if you can offer them cheap enough maybe people will not mind. Looking forward to results.
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Wedge1967's Avatar
Car: '07 335i e92
Default 02-24-2015, 11:28 AM
Originally Posted by VargasTurboTech
Lots of stuff you are not addressing
Can you elaborate? Not everyone understands Turbo-101... (no pun intended)
Default 02-24-2015, 11:41 AM
Not really, would prefer to just watch, and see how things progress.
www.Vargasturbo.com
alvin's Avatar
alvin alvin is offline
Car: 2009 335 i xdrive
Default 02-24-2015, 01:31 PM
then why say anything?
2009 335 Xdrive pulled by a Newfoundland
Spxxx's Avatar
Spxxx Spxxx is offline
Default 02-24-2015, 03:06 PM
Because he was referenced by the OP...
Tony, good job taking the high road on this one after some blatant strikes at your product by the OP. I was expecting you to blow up haha... PM me so we can setup a time for me to come see the new shop.
