robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default MOTIV Single turbo DIY - 01-10-2015, 12:32 PM
For some reason I cant post it here.
Here is link
http://www.e90post.com/forums/showthread.php?t=1077600
BostonBeemah's Avatar
Car: AW 135i
Default 01-10-2015, 12:50 PM
Finally!!
RIP 2008 AW/BL 135i
houtan houtan is offline
Default 01-10-2015, 01:37 PM
Niice!
EOD23 EOD23 is offline
Car: 09' 135i
Default 01-10-2015, 02:15 PM
What an incredible DIY!
robc1976's Avatar
Car: 2007 335i
Default 01-10-2015, 02:16 PM
I appreciate it!
Default 01-10-2015, 02:57 PM
My goodness, i commend you. That is not easy to do at all considering the amount of pics and time put into this. Well done.
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 01-10-2015, 03:36 PM
excellent diy
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
robc1976's Avatar
Car: 2007 335i
Default 01-10-2015, 06:44 PM
I appreciate that man!
Rob.K Rob.K is offline
Car: 08 135i 6MT
Default 01-10-2015, 09:31 PM
Wow... incredible work! Thank you very much! Will be using that for my install
Current - 2008 135i 6MT | XR9567
Sold - 2007 335xi AT | 12.1@117
robc1976's Avatar
Car: 2007 335i
Default 01-10-2015, 10:01 PM
Thank you, it was a blast!
Blaizon Blaizon is offline
Car: 2008 E92
Default 01-11-2015, 12:57 AM
Nice work!
2008 Sparking Graphite 335i 6MT Coupe - JB4/FFTEC
2007 Montego Blue 335i 6AT Sedan
robc1976's Avatar
Car: 2007 335i
Default 01-11-2015, 02:56 AM
Few pics, engine bay is dirty but oh well lol!
Default 01-11-2015, 10:46 AM
One genuine question about oil feed line. You dont think it will get too hot being so close to turbo exhaust housing?
robc1976's Avatar
Car: 2007 335i
Default 01-11-2015, 11:16 AM
I don't think it will. They tested this on there race car for over 10,000 hard miles with no issued.
Default 01-11-2015, 12:09 PM
robc1976's Avatar
Car: 2007 335i
Default 01-11-2015, 12:16 PM
damn ice storm just moved in!
HouseN54's Avatar
HouseN54 HouseN54 is offline
Default 01-11-2015, 12:49 PM
Very very sneeky I like it!
livnpaintball2 livnpaintball2 is offline
Car: 135
Default 01-11-2015, 03:03 PM
LOVE IT!!
2016 Mustang GTPP Whipple! 650rwhp, easy..
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Thor 12.9 mega motor installed!
Default 01-11-2015, 08:55 PM
damn.
robc1976's Avatar
Car: 2007 335i
Default 01-11-2015, 09:20 PM
damn.
torture!
robc1976's Avatar
Car: 2007 335i
Default 01-13-2015, 12:02 PM
Little vid for you guys, I was a bit over excited and talked to damn much!
Car: AW 135i
Default 01-13-2015, 01:21 PM
Intoxicating sound! You can tell the how happy the car is from just that one start. Sounds so smooth compared to others I've heard.
RIP 2008 AW/BL 135i
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 01-13-2015, 02:28 PM
I think this Motiv 750 kit is going to be what keeps me on this platform!!
robc1976's Avatar
Car: 2007 335i
Default 01-13-2015, 02:31 PM
Its a different car entirely
Car: BMW 335i e90
Default 01-13-2015, 02:44 PM
I'll have to get with you about the drivability etc etc later after you've had some time behind the wheel! If things don't move forward with fueling etc on this platform than I'm switching over to a C6 Z06. Literally halted my build to see how this kit performs on the street!
