(#51)
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 01-20-2015, 11:03 AM
My 335i is european. I heard that some erros could appear since the flash is made for US cars.. can anyone do one with EU values?
grinchxvx's Avatar
grinchxvx grinchxvx is offline
Car: 2008 135i
Default 01-20-2015, 12:07 PM
I'm FBO on 91 oct and hitting 14-15 psi autotune with map 5.
Think I would benefit from getting this flash? Car feels good but there's always room for improvement.
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 01-24-2015, 01:44 PM
You will get a permanent Engine management light if you flash a US map because of the DMTL sensor we don't have in Europe.
You can copy all the values of the map using your own bin, Tuner pro and and correct .xdf. There is a catch though. You must copy all values BUT the torque monitor ceiling sheet. If you alter the torque monitor ceiling values (and a few other maps, some of which are not mapped in the xdf yet, but the back end flash don't modify them), the engine won't start. That's because the torque monitor ceiling belongs a memory zone that needs to be re-signed if it's altered, unfortunately the free flashing tool can't do that. I'm working on a solution.
trebila's Avatar
trebila trebila is offline
Default 01-24-2015, 02:58 PM
This , and euro cars have a higher MAP Max voltage which shouldn't be edited too.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 01-24-2015, 03:10 PM
What happens if you edit it?
trebila's Avatar
Default 01-24-2015, 03:27 PM
Not sure, but you certainly rescale the voltage<->psi conversion, leading to a slight false boost read.
AUS and EURO car have a higher MAP max voltage than US cars.
Eristoff's Avatar
Default 02-05-2015, 01:59 PM
So, resuming, i should copy everything except the "no identified" zones, torque monitor and Voltage?
Whateva's Avatar
Whateva Whateva is offline
Car: E90
Smile 03-04-2015, 12:45 PM
With the pump gas back end flash we suggest map 1 for 91 octane and map 2 for 93 octane.
Sorry late to the party over here. Here is Cali we only have 91 as you know Terry. I do have an e85 pump near by. If I i do the 40/60 mix to get my 93 would that be sufficient to run map 2 with a pump flash? or does that defeat the purpose?
2011 F10 535i | D Shoup Flash | PS2 | GFB DV+ | Wagner FMIC | Helix Overdrive | Sprint Booster | CDV Mod | Koni Yellows | Eibach Sports | M5 Sways | Spec 2 Clutch | SMF | UUC SSK | Custom Inlet | Custom Dynomax Exhaust
brainsurgery brainsurgery is offline
Car: BMW E91 LCI 335xi
Default 03-12-2015, 05:22 AM
What happens if I use map 0 and pump flash?
When I take the car to yearly inspection or dealer, I usually switch to map 0.
Duperstar Duperstar is offline
Car: 2009 535i xdrive
Default 03-12-2015, 09:09 AM
I think some of the *** emissions monitors are turned off in the BMS flashes.
2009 535xi - JB4 G5 ISO -BMS Race Flash- BMS Intake - ER CP- Forge DVs- Active Autowerke intercooler- Gone
Activehybrid 3 - JB4 EWG/OBD- CTS Turbo Intake- VRSF CP- Bavsound Stage 1- current
tc535i tc535i is offline
Car: 95 M3, 01 330i, 07 335i
Default 06-18-2015, 02:07 PM
Just saw this thread... I've logged and can definitely feel timing pulls on map 2, doesn't show up at all on map 1. Running the pump gas flash, 91, FBO with a 450 walbro. Did 418/439 on 2/3 e85, same flash, map 7 and no timing pulls so I'm pretty sure it's running well.
Here's the log, any input? Seems like she's falling flat on her face around 4300
http://***********/u/tc535i/lunchtime...4-11&zoom=0-18
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 06-18-2015, 02:17 PM
looks like the JB4 went into failsafe due to misfire
update firmware and interface and post a log in map 1 and map 2 in the support section
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Default 06-18-2015, 02:22 PM
would a misfire be logged in the shadow codes or anything? I've never pulled any misfire codes, just a failed thermostat for the last few months.
I don't really have the resources to update the JB4 right now, I kinda figured I could "set it and forget it" once I had the car running right :/
Guess I'll try back when I can figure out how to get the jb4 firmware up to date
Here's the dyno log from 3 weeks earlier if that lends any insight http://***********/u/tc535i/8214-eas-...1&zoom=176-219
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 06-18-2015, 02:35 PM
if you can take logs, updating the firmware is no different
misfire codes don't always show up, and sometimes will be deleted if the auto clear function is on
from the logs: you are running an incorrect flash for your fuel; trims are too high, AFR too rich, insufficient timing advance.
535abe 535abe is offline
Car: 2010 535i Msport
Default 06-25-2016, 10:02 AM
Hey guys so i am planning to run an e50 mix with 91 on my car and was wondering if i had to get the e85 flash or just get the pump flash and run map 7. Also if i do the e85 flash do i have to have e85 all the time or will the car adjust to when i don't have e85 like map 5 would.
2010 535i Msport, ER chargepipe, Injen DCI, 7" VRSF FMIC, VRSF DP, JB4 G5
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-30-2016, 12:21 PM
running e50 with the pump flash is not really adequate as the fuel scalar my prove insufficient (fro 30% e85 fine but e50 is 2x more ethanol), and you'll get a timing advance curve suited for pump, not e85 mix - that leaves a lot of power on the table.
Best practice is to flash the proper backend when changing fuel type.
Default 06-30-2016, 01:22 PM
The RACE flash is setup as a hybrid setup that will work with pump and E85 mixtures. But, for straight 91 octane, I'd want to be on the PUMP flash. The PUMP flash can support up to around 30% E85.
Jg3660 Jg3660 is offline
Car: 2008 335xi jb4-
Default 08-12-2016, 08:49 AM
So in order to do the Bimmerboost flash, I need a Bavarian technic cable? It can't be done using the jb4 usb cable? Wanna make sure before I spend more money haha
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 08-13-2016, 02:45 PM
For bimmerboost, the $179 cable.
For MHD, $40 KDcan cable from bimmersoftware.com and $79 Android software which comes with more capabilities than bimmberboost
Default 08-14-2016, 08:19 AM
I have a jb4 that I need to get some use from because it was a little expensive but I've heard of the MHD being a great option. I might have to look a lot more into that. And no androids here man! iPhone only haha.
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 08-14-2016, 04:50 PM
If you want to go the BB route and not deal with an Android device, PM me and I can sell you my Bav Tech cable (for a lot less than $179).
grim54 grim54 is offline
Car: 2007 bmw 335i e90 n54
Default 08-14-2016, 06:20 PM
This is all with the BB flash right? How would the mhd flash differ? And with 93 and meth would the race flash be better?
2007 335i e90 JB4 G5, MHD bef, HKS bov, 7" FMIC, BMS meth kit, passenger side silicone inlets, custom oil cooler retrofit with setrab core and AD Engineering thermostat and Apex ARC8 19" wheels. Aka my Silver Queen.
Seven11 Seven11 is offline
Car: 535i
Default 08-14-2016, 09:21 PM
i would stay FAAAAR away from a bimmerboost back end flash. there were cases of people bricking their ECUs. Nothing like that will happen with MHD. I dont think a single person is running a bimmerboost backend anymore.
just go with an MHD back end, that what i use with my JB4.
- BMW 535i - Sport - Sport Auto - JB4 G5 ISO - DCI - BMS E85 BackEnd via MHD - 19in M6 Wheels -
- Suzuki GSX-R750 - Akrapovic Titanium Exhaust - Mirror Block-Offs - WoodCraft RearSets - Yoshimura Frame Sliders -
Car: '07 335i 6MT
Default 08-15-2016, 12:25 AM
There are plenty of people using the BB backend flash... mine is currently on one. The software is fairly easy to use too. MHD hasn't been around all that long.
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 08-15-2016, 11:12 AM
+1
2009 335i e92 n54 | FBO | JB4 | e85 flash |
