musc's Avatar
musc musc is offline
Car: 335is DCT
Default 09-25-2013, 02:04 PM
Terry. How do you think this set up would fair with a stock IC and drop in filter? I am considering this set up for an otherwise stock 335is DCT with regular access to 93 E0 fuel. Thanks!
Default 09-25-2013, 02:58 PM
We don't have a free flash file yet for the IS models. But you'd be fine on map 2 and the factory is flash with 93 octane.
musc's Avatar
Car: 335is DCT
Default 09-25-2013, 06:41 PM
I saw a guy with a video on YouTube with a 335is running the JB4/BMS flash running 11.9/118mph with tune only. Any idea what flash that was?
Default 09-25-2013, 06:58 PM
The original back end flash that you load via a Cobb.
s142nv s142nv is offline
Default 09-26-2013, 02:26 PM
Originally Posted by bigdaddycain
Interesting, I always thought you preferred Map 5. I guess that was for cars without the BMS Flash?
switching to Map 2 when I get home....
I was under the same impression. I'm FBO w/ bms pump flash, is it safe to assume that I should be running map 2 now?
I'm currently running map 5.
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 09-27-2013, 04:45 AM
I could see map 2 being better than map 5 on a dyno (because you're in a building with NO changing conditions), but how is it better on the road? Is it because map 2 works better with the backend flash?
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
Jgnp15333's Avatar
Jgnp15333 Jgnp15333 is offline
Car: 2008 335xi
Default 09-28-2013, 01:45 PM
What kind of numbers did this car dyno pre-pump-flash on 91oct? I finally applied the pump flash to my DME and don't feel an appreciable difference.
Your post-flash 91oct hp numbers are comparable to my e85 numbers; so, I kind of expected that same "raped ape" feeling on 93oct post pump-flash as I got from the e85.
Logs posted - Also forwarded to BMS.
PS - Can you tell I need an intercooler?
mister_jp mister_jp is offline
Car: 335xi 2008 coupe 6spm
Default 09-29-2013, 10:16 AM
Hi guys, I just flash my car with the pimp flash and update to iso27.2 do I have to change setting in the jb4 ?
I remember that we have to put 0 some where but I don't remember where and I can't find the answer on the flashing thread.
Jgnp15333's Avatar
Car: 2008 335xi
Default 09-29-2013, 12:08 PM
Under the user adjustment tab in jb4, you want all zeroes in the all map afr and cps fields. You may also want to set the JB4 to ignore dme boost values by going into the steering wheel settings and enabling menu 4-2.
Default 09-29-2013, 12:13 PM
Thanks man ! Greatly appreciated !!!
Default 09-29-2013, 12:27 PM
=mister_jp;277407]Hi guys, I just flash my car with the pimp flash
I want THIS flash! Does this make your N54 run more smoove and command respect from all other cars!?!?!? "B!tch betta have my fuel!"
in all seriousness, make sure you change the drop down menu selection in the SETTINGS tab to G5 ISO with BMS Flash, 1M, or 335is.
Also make sure you RESTORE DEFAULTS under the FILE menu.
Stangorang's Avatar
Stangorang Stangorang is offline
Car: Car
Default 09-29-2013, 12:36 PM
I am not too up to date on the G5 board, but what is it about this combo that is allowing the n54 to make so much more power than Cobb alone on 91 oct?
I thought the major limitation with 91 oct was the timing, not fueling.
Default 09-29-2013, 12:37 PM
Hahaha hahaha sorry I M on my cell phone ! Thanks for the help !
BeGooD69 BeGooD69 is offline
Car: 2007 335i
Default 10-03-2013, 07:53 PM
ok so if I run, $%$^ , 91 (El PASO don't have 93 Grr), FMIC, AFe intake, Meth 70/30, wish back flash should I run? I think you send me Race (is there a new one?) and wut MAP is the best, like Bigdaddycain I thought MAP5 was the best..
Thx
Default 10-03-2013, 08:05 PM
Meth = race.
crazyyardie's Avatar
crazyyardie crazyyardie is offline
Car: 2007 335i
Default 10-23-2013, 11:33 AM
no ********* need for the map 1 91 octane or map 2 93 octane ? just jb4 g5 and intake ?
shaunlsone shaunlsone is offline
Car: 09 e92 335i sport
Default 10-23-2013, 10:24 PM
ordering my cable in a few days I wss expecting to get 380ish hp with my 35 to 40% e85 blend when I was on map 5 but I got 93oct here so map 2 it is and ill still mix in a little e85 or 100oct just for the hell of it
skyak skyak is offline
Car: 535 xit
Default 10-23-2013, 10:28 PM
I have same question!
JB4 w/ Bluetooth - DCI - BB Pump Gas Flash - SAT Flash - LED Side Markers - SAT 35 Tint - Kickdown Delete - KW V3 - 135M Wheels - 10mm front / 15mm rear wheel spacers - Michelin Pilot Sport A/S 3
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 10-24-2013, 09:00 AM
Just enought octane to run either Map.
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 10-25-2013, 11:39 AM
So wait the backend flash makes this big of a difference?? I have the g5, intake, and ********* and don't think my numbers are near that high.
Default 10-28-2013, 08:53 AM
Every dyno reads differently. But the pump gas back end is a great upgrade IMHO.
Alex450whp's Avatar
Alex450whp Alex450whp is offline
1Fast1
Default 12-14-2013, 12:06 AM
Will we need to upgrade fuel pump to run e85 on a stock 335i with jb4 and back flash??
2009 135i (MT)
Doc Race 6266, TurboSmart/Emptuning tune, Vrsf 7.5 intercooler, Spec Twin Dics Stage3+ w/ Mfacory smfw.
Bimmerlife Coils, H&RCoilovers, RTD Short Shifter, AA Gen 2, Fuel-it PI/750cc with stage 4 LPFP, Koiser 17in with MT
720WHP
musc's Avatar
Car: 335is DCT
Default 12-14-2013, 02:25 AM
To run high concentrations, yes. Every car is different on what it can handle. The key is logging to watch your low and high fuel pressures. Most stock fuel systems will be good for E30-50. Some will have issues lower than that, some will be able to get away with more. My car didn't like more than E45. There is an inline pump that basically augments your stock low pressure fuel pump (LPFP) and allows you to run more E85. There is a link to the DIY on how to install this below.
I would start by verifying the ethanol content at you local station. Right now winter blends are going to contain less than 85% ethanol. My local station is E77. You can go as far as test your 91/93 octane as well, which should be about 10%. Then you can more accurately calculate your Ethanol content going into the car. I would start with E30 and log. Move up to E35, log, E40, log. etc.
I would stay with the race flash until you hit about E50. At that point you can try the E85 map.
Walbro GSL392 inline LPFP DIY
http://www.n54tech.com/forums/showthread.php?t=20721
335is DCT
malrayes's Avatar
malrayes malrayes is offline
Car: 2012 BMW 640i F13
Default 12-14-2013, 03:43 AM
Any idea when this will be done for the n55s?
2012 BMW 640i Coupe F13 | Dr. Euro Down Pipe | BMS intake | M Performance Exhausts | JB4 Stage 2
Alex450whp's Avatar
1Fast1
Default 12-14-2013, 08:15 AM
Thanks this will be fun
2009 135i (MT)
720WHP
