Hellraiserharris's Avatar
Hellraiserharris Hellraiserharris is offline
Car: 14' 435i
Default 07-31-2013, 03:38 PM
Originally Posted by knissel
I think it would be great for a sticky to be made going though a log start to finish. Like how to do it and what the chart / csv mean. Pretty much exactly what steveAZ said
I agree. Im still a noob with JB4. And it would be great to have a sticky showing each item with their expected range.
14' 435i. M-Sport, JB4 Stage 2, BMS Intake, more to come
Jnat Jnat is offline
Car: 09 335xi
Default 08-01-2013, 03:38 AM
I apparently like many would like to thank SteveAZ for taking the time to do that breakdown, very informative and helpful and that's what makes these communities what they are. I agree that it would be helpful for some of us if there was a sticky with what we should see on these logs. It would cut down on a lot of questions. But, anyhow thanks SteveAZ for taking the time.
09 335XI /Cobb ATR TUNED 18.5 psi/DCI/2ND ***** '''''''/E20/Alpina/VRSF 7inch/VRSF Chargepipe with Tial BOV***
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 08-01-2013, 04:47 AM
Thankyou ! ! !
Seavita Seavita is offline
Car: BMW 335 CSI
Default 08-01-2013, 06:42 AM
Originally Posted by SteveAZ
This should get you started....
It sounds like you're opening the run files in excel...open them in the JB4 software under Data logging/Open log.
As for your LPFP...you're fine right now and we can cross that bridge when we get to it. If you're HPFP isn't taking a dive...don't worry about it.
This is your log broken down for easy reading
Wow in thirty seconds of me reading this you have doubled my knowledge and tripled my understanding. Bothe Steve and Peder are both incredibly helpful on thsi board and should be recognized often and loudly!!!
Sleeper edition Cabrio 3 series
Performance: JB4/G5 ISO MHD Flash, RB's and HiFlow oil returns, BMS DCI, PLM ***, cp-e FMIC & OC, aFe scoops & Throttle body spacer, Alpina TCU Flash, Stage 2 LPFP bucketless and Platinum PI by SteveAz, Mspec LSD, Cp-e charge with tial BOV, RB inlets and VTT outlets (let them fight my car doesn't care)
Default 08-01-2013, 01:11 PM
Hahaha...we've all been there...there are a lot of good people on this board that have helped me...just paying it forward.
alpha8484's Avatar
alpha8484 alpha8484 is offline
Car: BMW 535i
Default 08-03-2013, 12:00 AM
thanks steve for your very informative explanation
you gonna hate me, but i read your reply after i did my pull today. this time i did turn off dtc and gun it real good. here is the file. anything bad i need to know?
oh btw the e85 is down to 18% as i didnt have access to an e85 station.
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 08-03-2013, 12:39 AM
Couple small timing dips at 3K and 4K. Besides that, looks pretty normal.
-Nick
2014 335i xDrive / Silver / ZF8 / M-Sport / 400M / BM3 2H Map / xHP Stage 3 / ATM FMIC / H&R Sports / VRSF **/CP
Default 08-03-2013, 10:51 PM
^what he said...but to add to that...I'm willing to bet that after you filled up again and your ethanol content dropped to 18%, you didn't reset map 5. Consequently, when you did that pull, your Avg. Ign started out pretty low and then said "WTF?" and climbed. For max power, you want high Ign. Adv #'s (above 10) and low Avg. Ign #'s (below 1.5).
If you change your blend, make sure to switch maps, even if just switching back to map 5. This will adjust your Avg. Ign. to a safe level (3.5) to relearn and reduce a little stress on the motor.
Nugs Nugs is offline
Car: 2011 135i
Default 08-04-2013, 06:21 PM
Great work SteveAZ!
Post #20 should get it's own thread and be made a sticky.
alpha8484's Avatar
Car: BMW 535i
Default 08-05-2013, 02:04 AM
thanks for your input Steve. One more question, if i switch maps because of blend changes, do i have to gun it a few times in 3rd gear just like map 5 before the map kicks in?
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 08-05-2013, 06:33 AM
Steve, that is excellently done. Needs to be a sticky!
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
Car: BMW 335 CSI
Default 08-05-2013, 09:39 AM
Have to??....no....should...ABSOLUTELY, I go further and set the JB4 to Map 0 and shut the care off after fill up and then restart and switch to map 5 and do 3+ pulls. Overkill maybe? but I get very few codes day to day and only went in to limp once since having the JB4, that was when I did this routine and then left it in Map 0 by accident and tried to gun it with fresh e85...wooops lol...., so will keep doing it even if it does take a few extra minutes.
