robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default Another meth nozzle mod LOL!! - 07-06-2013, 10:22 PM
I have done quite a few of these, sorry LOL!! The previous way with selonoid on 90 degree Nozzle holder the nozzle holder/nozzle kept coming unscrewed. I figured this way with line coming from the top it would not put side to side pressure and keep tight and catually flow better with faster response. It works perfectly!!
Here are the parts you need (thanks to members "blaster3500" & "N8N" ) for searching the web for me...I couldnt find them LOL!!
1/8" NPT to -4AN
http://paceperformance.com/i-6253698...ight-blue.html
Female -4AN to -4AN smooth transition 90 degree
http://www.jegs.com/i/Earls/361/9351...oductId=749382
Pics:
aoschadlin's Avatar
Car: 535i
Default 07-06-2013, 10:50 PM
Looks good. Not sure it'll work on my setup though. That dang DCI is in the way. I haven't done any mods to them and I have my meth bung in the CP.
I did notice that my connector had come loose though. Hadn't even been using it.
robc1976's Avatar
Car: 2007 335i
Default 07-06-2013, 10:58 PM
It should, keep in mind my DCI are bigger than BMS.
aoschadlin's Avatar
Car: 535i
Default 07-06-2013, 11:01 PM
You know I'll order the parts and give it a go regardless.
I just got the last setup installed yesterday and am having some controller issues so haven't even been able to actually use the system yet.
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 07-06-2013, 11:21 PM
Nice idea Rob!Looks more secure.if Earl's made a Female 1/4 NPT to Female -4AN Swivel 90 Degree it would shorten it up a little.Getting rid of that coupling between the nozzle & elbow.Little lower profile.Again great rite up
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 07-07-2013, 12:13 AM
Originally Posted by N54 TuNeR
Nice idea Rob!Looks more secure.if Earl's made a Female 1/8 NPT to Female -4AN Swivel 90 Degree it would shorten it up a little.Getting rid of that coupling between the nozzle & elbow.Little lower profile.Again great rite up
Fixed it for ya.
-Nick
2014 335i xDrive / Silver / ZF8 / M-Sport / 400M / BM3 2H Map / xHP Stage 3 / ATM FMIC / H&R Sports / VRSF **/CP
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 07-08-2013, 07:32 PM
Originally Posted by e46m3to335i
Fixed it for ya.
-Nick
thank you
SOLD
PRESENT RiDE
robc1976's Avatar
Car: 2007 335i
Default 07-08-2013, 07:51 PM
I agree....I wish I could find one!!! Even better response to.
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 07-08-2013, 09:43 PM
http://www.summitracing.com/parts/ear-991401erl
im redoing my meth now,ill probably end up trying your setup.I did find this.not sure how the inside looks,but i may get this too.wont break the bank.im looking for a secure tight short setup too.One side into nozzle & other into solenoid.
SOLD
PRESENT RiDE
aoschadlin's Avatar
Car: 535i
Default 07-08-2013, 09:52 PM
So the advantages here are the lower likelihood that it will loosen?
Cause it still has the same hard 90deg turn so unlikely to provide a "smoother" flow.
robc1976's Avatar
Car: 2007 335i
Default 07-08-2013, 10:47 PM
I wouldn't that does not have a smooth flow...it is to sharp if a bend (meth hits the wall and then goes to the nozzle)...not smoothly.
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 07-08-2013, 10:48 PM
Yeah its not as smooth as Rob has posted but just brainstorming.
SOLD
PRESENT RiDE
robc1976's Avatar
Car: 2007 335i
Default 07-08-2013, 10:51 PM
So the advantages here are the lower litkelihood that it will loosen?
My set up fires not have a hard turn, it does not have a abrubt turn ...it flows smoothly. Basically a hard 90 degree turn the meth hits a wall then goes to the nozzle. Mine has a smooth bend and no obstruction.
aoschadlin's Avatar
Car: 535i
Default 07-08-2013, 10:57 PM
Yep, understood. Was actually referring to the one that N54 Tuner was showing us.
What we need is a magical Female -4AN to 1/8 NPT smooth transition.
I wonder how hard it would be to ask Earls to make 'n' units that match that?
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 07-08-2013, 11:02 PM
I have been searching all over the internet & couldn't find one.there's every other one out there but that one lol.that would be perfect setup.but it wouldn't hurt to call them.
SOLD
PRESENT RiDE
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 07-09-2013, 06:14 AM
This morning I sent emails out to Summit Jegs Earls and 4 other big name places to see about that fitting.just waiting now.
SOLD
PRESENT RiDE
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 07-09-2013, 09:09 AM
So far Jegs said no way
I got ANPLUMBING said they don't have it but can make then.minimum run is 50 pieces at 30.00 each.that's too many.unless there's 50 people wanting this then at 30.00 each.still waiting on EARL SUMMIT & few others to respond.little surprised that there's every other size out there except this one lol.
SOLD
PRESENT RiDE
BMWpurist's Avatar
BMWpurist BMWpurist is offline
E90post reject
Car: Overpriced Econo Box
Default 07-09-2013, 09:37 AM
Your meth injection setup is professional grade, it makes mine look like something Mickey Mouse installed.
My friend died doin what He loved,Heroin.
robc1976's Avatar
Car: 2007 335i
Default 07-09-2013, 11:13 AM
oops lol!
robc1976's Avatar
Car: 2007 335i
Default 07-09-2013, 11:16 AM
thanks! It is getting there!
Mactango's Avatar
Mactango Mactango is offline
Default 07-09-2013, 11:22 AM
Rob, how much wheel HP are you actually putting to the ground? You have like every mod ever made for the N54 awesome
'09 135i AT | JB4 G5 | Wedge E85 Flash | Alpina Flash | RB Turbos | Walbro 255 | Evolution Racewerks CP | Forge DV's | ER FMIC | aFe DCI | Macht Schnell DP | Borla Dual Race Exhaust | NGK 5992 | BMS Oil T-Stat Bypass | BMS OCC | BMS Cowl Filter Covers
