robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 01-30-2013, 07:14 PM
Moved the selonoid much closer (From 12" to 3") to nozzle, less drain and possible better response.
GetSomeE92 GetSomeE92 is offline
Car: '09 E92
Default 01-30-2013, 10:08 PM
Originally Posted by robc1976
I didnt really get a kit...I basically made my kit by ordering everything...because there kit had pieces you do not need for JB4 intergration:
Here is what I got:
250psi pump:
http://www.alcohol-injection.com/en/...tion-pump.html
4-AN Stainless line upgraded: (Comes with nozzle holder, pump fittings, selonoid fittings) but be sure to put in comments you are NOT using a ckeckvalve but a 250 psi selonoid.
http://www.alcohol-injection.com/en/...-line-set.html
250psi Selonoid: (Be sure to select 4-AN)
http://www.alcohol-injection.com/en/...-solenoid.html
Nozzle: (Depends on your mods.....I have the largest DO14)
http://www.alcohol-injection.com/en/49-nozzles
Tank: (If getting race tank you will need a push in fitting on inlet of pump)
http://www.alcohol-injection.com/en/...mped-tank.html
You will need a BMS FSB that can be purchased here (scroll down to FSB controller):
http://www.burgertuning.com/meth.html
You're the man. Thanks for posting this.
robc1976's Avatar
Car: 2007 335i
Default 01-30-2013, 10:14 PM
no problem
robc1976's Avatar
Car: 2007 335i
Default 01-30-2013, 11:02 PM
Thinking about putting the 2nd nozzle in location below, possible may just get a new CP with dual nozzles....but I like them spaced out a bit. If I go dual nozzle I will but 90 degree ends on the lines from nozzle to selonoid.
robc1976's Avatar
Car: 2007 335i
Default 02-01-2013, 10:37 PM
Decided to make seperate thread on the dual line upgrade:
http://www.n54tech.com/forums/showth...991#post247991
torres335i torres335i is offline
Default 02-03-2013, 07:53 PM
does the tank come with fitting?
robc1976's Avatar
Car: 2007 335i
Default 02-03-2013, 07:59 PM
I had them install it to, I may get another tank and see if it is possible to put a 4-An fitting in a different location, but I think it has to be in the location already tapped because of the baffle design and thats not really possible to put a 4-AN fitting because you can not hold the nut behind the tank because of the location.
Default 02-03-2013, 08:00 PM
so the tank has no fitting when bought new?
robc1976's Avatar
Car: 2007 335i
Default 02-03-2013, 08:03 PM
fitting comes with it but not installed (bulk head fitting)....unless you specify to.
Default 02-03-2013, 08:07 PM
so if i order the race tank it will come with a fitting but not installed?
robc1976's Avatar
Car: 2007 335i
Default 02-03-2013, 08:42 PM
as far as I know yes, I called them up and told them to install it before shipping.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 02-04-2013, 08:40 PM
Hey rob,
So in terms of hose lengths, can you clarify that it's:
14" from pump to solenoid
3" from solenoid to nozzle
What's the length from tank to pump?
Thanks again.
robc1976's Avatar
Car: 2007 335i
Default 02-04-2013, 09:41 PM
Originally Posted by _ink
Hey rob,
Thanks again.
You have to mount your pump like mine and you will have some left over wich I just routed underneath to take up slack.....if you want less left over make it 13 ft...I just like haveing more than not enough.
Yes:
14'
3"
For pump to tank it dep[ends on how you route yours, what tank are you getting? I have the race tank and they gave me 4 ft I used about 18"....I am still possibly getting the same tank, untapped and put in my own 4-AN fitting. If so I will have a brand new tank (Push in fitting) for 85.00 shipped if you want to wait
Default 02-08-2013, 04:46 PM
did apply thread paste on all the threads?
robc1976's Avatar
Car: 2007 335i
Default 02-08-2013, 05:51 PM
All NPT threads, not 4-AN.
Default 02-08-2013, 05:57 PM
Ok thanks any specific brand on thread paste?
robc1976's Avatar
Car: 2007 335i
Default 02-08-2013, 08:56 PM
I have a pic of it here
http://www.n54tech.com/forums/showthread.php?t=18541
_ink's Avatar
Car: 335i DCT
Default 02-09-2013, 07:31 PM
Yo Rob, if you were going to install a flow sensor in this setup, would it be installed from pump to tank?
robc1976's Avatar
Car: 2007 335i
Default 02-10-2013, 01:34 AM
the selonoid I use is a flow sensor.
_ink's Avatar
Car: 335i DCT
Default 02-13-2013, 08:30 AM
That's the DO solenoid? So it can be hooked up to a gauge like the P3?
robc1976's Avatar
Car: 2007 335i
Default 02-13-2013, 09:31 AM
hooks up exactly like the BMS selonoid ones...had 2 wires 1 for power & 1 for ground not polarity specific.
aoschadlin's Avatar
Car: 535i
Default 04-25-2013, 09:20 PM
Yes:
14'
3"
Hey Rob
Did you run your 14' length under the car, or inside the cabin?
I'm going to be tackling this, likely on my own, next weekend. Would be good to attack it properly the first time.
robc1976's Avatar
Car: 2007 335i
Default 04-25-2013, 09:44 PM
Originally Posted by aoschadlin
Hey Rob
run it under the car, was enough to go all the way to the intercooler piping.
alvin's Avatar
alvin alvin is offline
Car: 2009 335 i xdrive
Default 04-29-2013, 09:34 AM
under the car is easy and the way to go in my opinion. Just remove the underbody pannels. It's probably around 8 bolts on the drivers side. Pull it down and slip the line inside. I ran it into the engine bay through the wheel well.
2009 335 Xdrive pulled by a Newfoundland
_ink's Avatar
Car: 335i DCT
Default 05-08-2013, 09:08 PM
Rob and Alvin,
Did you both get around to solving that FSB controller issue you were experiencing?
