impaaale impaaale is offline
Car: BMW 335i Coupe -07
Default Rought idle power loss, checked everything PLEASE HELP - 08-16-2020, 11:57 AM
Hi guys, first i wanna apologize for my english as i am from sweden.
I got a problem with my car which is getting me crazy..
So i drove another day and the engine started shaking so i stopped, i checked all the coils and felt so everything was good and started it again.
Car went normal but felt a little more powerless..
As i drove home the same thing happened but it never got back to normal.
This happened after i installed an helix overdrive.
I am not getting no codes at all thats the worst thing so i dont really know what the problem is.
Im going, DP, IC, oil catch can, stage 2 lpfp, helix overdrive, pure stage 2 cast, tialbov, PR coils etc the normal things when u go for 22-23 psi custom maps.
I have checked my injectors and cleaned them.
I have tried my original ignition coils and the RP ones.
I have switched the spark plugs to new ones, (they where only 2 months old but i had nothing more to check)
I have checked my lpfp and everything seemed to be fine.
I have deleted the helix overdrive and tried without it.
I have checked my solenoids and also cleaned them.
I have checked my lambda but they where fine.
I have checked for leaks but not a single leak.
I have checked my mosfets and they where fine to.
I have checked the comprision in the engine and thats good to.
And i have ofcourse tried to go for stock map.
Still this shaking and power loss, its most at 1k rpm when i idle.
Anyone has had this experience?
I dont really know what to do more, the most anoying thing is that i have no codes at all?
Please help guys anyone who knows what could be causing this
i hope u understand my english...
Stay safe!
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 08-16-2020, 12:12 PM
Read through this Then follow their instructions to reset your adaptions.
It does make a difference.
No matter how fast I go there's always someone slower in front of me.
You can lead a horse to water but you can't make him Jet Ski.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
dcafs dcafs is offline
Car: BMW 135i Coupe
Default 08-17-2020, 08:19 AM
These articles refer to the European N53 engine variant which runs in stratified mode fuel injection, and how the NOx sensor and NOx converter can have an impact on fuel adaptations resulting in rough running engines
Seems like stratified mode was removed for the North American market due to high sulphur content in our fuel.
I don't think that the N54 engine uses stratified charge, nor do the North American variants have a NOx sensor/converter.
08 335Ci's Avatar
Car: 08 335Ci
Default 08-17-2020, 09:09 AM
The OP is from Sweden, I believe that's still in Europe.
Also if you read through the articles, it's for the MSD80 DME, same one used on the 'early' N54's. I did the reset on my MSD81 DME and there was a noticeable improvement in idle and low speed throttle response.
Why not try it? It's a couple hours of controlled driving and about 1/2 tank of gas and if it cures your rough idle / running, it's a lot cheaper then replacing coils, plugs and injectors with no results.
My reasoning for suggesting this is: by adding the helix he may have rail pressure reading that conflicted with his stored fuel trims.
albertc albertc is offline
Car: 2007 335i
Default 08-17-2020, 09:53 AM
make sure you don't have any vacuum lose
Example: line on the side of the throttle body, etc. You should have replaced cams and crankshaft position sensors just in case ( most likely not the problem )
JB4 flash with JB4, 4.0 bar sensor, DocR 6870, Race InterC, FuelIT stage 3 (525), Helix OverDrv 3x, Phoenix Intake with PI (750cc) with BMS controller, PrRW coil pack kit, WaveTrc Diff. E85
Car: BMW 135i Coupe
Default 08-17-2020, 10:09 AM
I did read the articles
I went even deeper and the author indicated that resetting adaptations is only a temporary solution if the underlying cause is not addressed.....which in his view was a faulty NOx problem affecting the ability of the DME to stabilize ongoing fuel adaptations for individual cylinders. Over time this can lead to rough idle, bad lumpy cold starts, jerky engine behaviour and loss of power and fuel efficiency because the stratified injection adaptation cycle stops completely when the NOx system is in a fault condition which allows fuel adaptations to get out of normal ranges over time.
Makes no difference that it was MSD80......the NOx issue is a European feature. So maybe it is relevant for the OP, but it does not apply to the North American market.
If you post advice like this you need to mention that it does not apply to all.....sends people on a wild goose chase looking for their NOx sensor/converter.
This forum is created by U.S. based company and many of it's members are North American.
Resetting adaptations is common advice on these forums and while I don't disagree that it can work in certain situations, it often is temporary and the same issues come back over time requiring more adaptation resets.
The author's point was that adaptations are designed to occur in order to keep things running smooth and within normal operating tolerances.....if you are constantly having to periodically reset them, then you have not found the underlying cause of the imbalance.
08 335Ci's Avatar
Car: 08 335Ci
Default 08-17-2020, 01:39 PM
I wish this COVID BS would end. The longer it lasts the bitchier and more confrontational people seem to get.
You missed where it's said if you replaced fuel pressure sensors, O2 sensors, injectors resetting adaptions will force the DME to relearn the new parts quicker. That is if you don't want to wait for an unknown amount of drive cycles and miles driven.
If you crave confrontation, go to Sturgis and hold up an ANTIFA sign.
08 335Ci's Avatar
Car: 08 335Ci
Default 08-17-2020, 10:23 PM
And I'm not your type, I'm heterosexual.
Car: BMW 135i Coupe
Default 08-18-2020, 05:54 AM
Bwahahahahaha..........OK Karen
Default 08-18-2020, 12:59 PM
Where is the love guys?
Have you tried removing the helix?
